galfert
Raspberry Pi 4 B - HDMI over USB-C
Tue Jun 25, 2019 3:59 pm
Is is possible to get HDMI output using the USB-C port on the Raspberry Pi 4 B?
I suppose you'd need to provide power via PoE to free up the USB-C port or use some sort of OTG power splitter cable if it exists. Or even better if you could somehow use the NexDock 2 an then only use a single USB-C cable between them, that would be awesome.
Re: Raspberry Pi 4 B - HDMI over USB-C
Tue Jun 25, 2019 4:22 pm
No, this is not possible. There is no route from the graphics system to the USB system for video.
W. H. Heydt
Tue Jun 25, 2019 8:31 pm
Hmm... USB-C port would appear to right out, since it doubles as the power connector, however... I have a Pi2B that drives a 10" adequately through some adapters off a USB 2 port (the native connection on the display is DisplayPort...an early Packed Pixel unit). One would, therefore expect it to be possible to that using a USB 3 port and go to something with pretty good resolution.
thagrol
Tue Jun 25, 2019 9:08 pm
Won't that be using DisplayLink or a similar proprietry protocol? As I recall there is no direct support for GPU output over USB2.
Attempts to contact me outside of thes forums will be ignored unless signed in triplicate, sent in, sent back, queried, lost, found, subjected to public enquiry, lost again, and finally buried in soft peat for three months and recycled as firelighters
W. H. Heydt
Tue Jun 25, 2019 9:12 pm
All I can say it that I set it up and it works. The second gen Packed Pixel displays are supposed to have optional HDMI and the second gen DisplayPort is supposed to work with HDMI, as well. Plus, their second kickstarter campaign included a 13 in. 4K panel.
