mikerr
Pi4 Sysbench results
Tue Jun 25, 2019 2:39 pm
I previously ran sysbench to compare Pi3B and Asus Tinkerboard, so added pi4 to the mix:
 sysbench --num-threads=4 --test=cpu --cpu-max-prime=20000 --validate run
Number of threads: 4
Pi 3B
    total time:                          129.6265s
    per-request statistics:
         min:                                 47.69ms
         avg:                                 48.12ms
Asus Tinkerboard
    total time:                          82.5418s
         min:                                 32.63ms
         avg:                                 33.00ms
Pi4B
    total time:                          62.6426s
         min:                                 24.95ms
         avg:                                 25.05ms
goodburner
Re: Pi4 Sysbench results
Fri Jun 28, 2019 10:31 pm
rasbperry pi 3b+
[email protected]:~ $ sysbench --num-threads=4 --test=cpu --cpu-mae=20000 --validate run
sysbench 0.4.12:  multi-threaded system evaluation benchmark
Running the test with following options:
Additional request validation enabled.
Doing CPU performance benchmark
Threads started!
Done.
Maximum prime number checked in CPU test: 20000
Test execution summary:
    total time:                          95.4187s
    total number of events:              10000
    total time taken by event execution: 381.6150
         min:                                 32.57ms
         avg:                                 38.16ms
         max:                                126.70ms
         approx.  95 percentile:              38.36ms
Threads fairness:
    events (avg/stddev):           2500.0000/10.51
    execution time (avg/stddev):   95.4037/0.01
raspberry pi 4b
[email protected]:~ $ sysbench --num-threads=4 --test=cpu --cpu-max-prime=20000 --validate run
Threads started!
 Done.
    total time:                          62.8740s
    total time taken by event execution: 251.4166
         min:                                 24.94ms
         avg:                                 25.14ms
         max:                                115.22ms
         approx.  95 percentile:              25.08ms
Threads fairness:
    events (avg/stddev):           2500.0000/4.58
    execution time (avg/stddev):   62.8541/0.01
zerschranzer
Sun Sep 15, 2019 1:40 pm
[email protected],75ghz
Threads started!
Done.
    total time:                          53.7144s
    total time taken by event execution: 214.8269
         min:                                 21.38ms
         avg:                                 21.48ms
         max:                                 72.57ms
         approx.  95 percentile:              21.48ms
Threads fairness:
    events (avg/stddev):           2500.0000/1.22
    execution time (avg/stddev):   53.7067/0.01
ejolson
Sun Sep 15, 2019 8:42 pm
Threads started!
Done.
         min:                                 21.38ms
         avg:                                 21.48ms
         max:                                 72.57ms
Threads fairness:
Rather than overclocking, you're better off running sysbench using a 64-bit operating system. Here are results from Gentoo:
$ sysbench --threads=4 --cpu-max-prime=20000 --validate cpu run
sysbench 1.1.0-74f3b6b (using system LuaJIT 2.1.0-beta3)
Validation checks: on.
Initializing random number generator from current time
Prime numbers limit: 20000
Initializing worker threads...
Threads started!
CPU speed:
    events per second:  2329.02
Throughput:
    events/s (eps):                      2329.0193
    time elapsed:                        10.0012s
    total number of events:              23293
Latency (ms):
         min:                                    1.70
         avg:                                    1.72
         max:                                    7.22
         95th percentile:                        1.70
         sum:                                39993.38
Threads fairness:
    events (avg/stddev):           5823.2500/6.30
    execution time (avg/stddev):   9.9983/0.00
Thus, the 64-bit sysbench cpu test at stock speeds is 5.38 times faster than the overclocked 32-bit result and 6.29 times faster than 32-bit at stock speeds.
As real programs run somewhere between 20 percent faster or slower on 64-bit, one conclusion is that the sysbench cpu test is nearly useless. In my opinion, a slightly more meaningful measurement of processor performance can be obtained using this Pi pie chart program.
jdonald
Sun Sep 15, 2019 9:03 pm
I wouldn't say sysbench CPU is useless, but acknowledge that a prime number sieve is not representative of everyday desktop usage.
I missed the sysbench discussion 1.5 years ago on this forum, but I believe I resolved any open questions here: https://www.raspberrypi.org/forums/view ... 3#p1518193
Restated, if you compile with -march=armv8-a+crc+simd -mtune=cortex-a72, the difference between 32-bit and 64-bit code disappears. In fact you need not even tune for Cortex-A72. I recall it even worked to do compile with -march=armv8-a+crc+simd -mtune=cortex-a7 because that's sufficient for udiv/sdiv instructions.
I know I've said this a lot, but people should be very careful when comparing ARMv6 code against anything more modern. This particular case is especially insidious because it doesn't resolve by installing the Debian armhf binary alone, as that is tuned for Cortex-A9.
ejolson
Sun Sep 15, 2019 9:34 pm
Those optimization settings for 32-bit binaries are interesting. I wonder what difference they make for Pi pie charts.
For the record, the sysbench CPU test does not perform a prime sieve but rather uses trial by division. Moreover, the divisions are performed with 64-bit arithmetic even though the maximum prime is set to 20000. From what I understand, the sysbench cpu code was originally a placeholder that was never meant to be widely distributed.
A parallel prime sieve is one of the tests in the Pi pie chart program.
ejolson
Mon Sep 16, 2019 5:29 pm
I've started a thread here to discuss whether the optimization settings -march=armv8-a+crc+simd affect the speed of 64-bit division during 32-bit mode operation on Cortex-A72 processors. So far I'm not seeing much improvement.
pi-tastic
Mon Sep 16, 2019 6:23 pm
WARNING: the --test option is deprecated. You can pass a script name or path on the command line without any options.
WARNING: --num-threads is deprecated, use --threads instead
sysbench 1.0.11 (using system LuaJIT 2.1.0-beta3)
Threads started!
CPU speed:
events per second: 1470.80
General statistics:
total time: 10.0020s
total number of events: 14713
Latency (ms):
min: 2.44
avg: 2.72
max: 17.61
95th percentile: 2.71
sum: 40001.49
Threads fairness:
events (avg/stddev): 3678.2500/3.77
execution time (avg/stddev): 10.0004/0.00
maccaps.com - bringing life to dead electronics.
ejolson
Mon Sep 16, 2019 7:33 pm
Threads started!
CPU speed:
General statistics:
Latency (ms):
min: 2.44
avg: 2.72
max: 17.61
sum: 40001.49
Threads fairness:
Am I to understand the above run was performed using a Pi 4B running Rasbian Buster? Could the compiler be so smart that it optimized the 64-bit divisions as 32-bit divisions?
ejolson
Mon Sep 16, 2019 8:07 pm
Threads started!
CPU speed:
General statistics:
Latency (ms):
min: 2.44
avg: 2.72
max: 17.61
sum: 40001.49
Threads fairness:
I've confirmed [Edit: I was unable to confirm] the above execution times on Raspbian Buster with sysbench compiled from source [Edit: what compilation options do I need?] using the commands:
$ git clone https://github.com/akopytov/sysbench.git
$ cd sysbench
$ ./autogen.sh
$ CFLAGS="-march=armv8-a+crc+simd -mtune=cortex-a72" ./configure --prefix=/home/pi/sysbench --without-mysql
$ make -j4
$ cd /home/pi/sysbench
$ ./sysbench --threads=4 --cpu-max-prime=20000 --validate cpu run
The speedup is very strange, because the code in question sb_cpu.c reads
int cpu_execute_event(sb_event_t *r, int thread_id)
  unsigned long long c;
  unsigned long long l;
  double t;
  unsigned long long n=0;
  (void)thread_id; /* unused */
  (void)r; /* unused */
  /* So far we're using very simple test prime number tests in 64bit */
  for(c=3; c < max_prime; c++)
    t = sqrt((double)c);
    for(l = 2; l <= t; l++)
      if (c % l == 0)
        break;
    if (l > t )
      n++;
  return 0;
which was clearly written with the intent to perform 64-bit divisions.
My conjecture is that the unusually fast run time results from a compiler aggressively optimizing a trivial benchmark [Edit: However, I'm unable to confirm this, because my Raspbian 32-bit binary still runs about 10 times slower].
ejolson
Mon Sep 16, 2019 8:12 pm
My conjecture is that the unusually fast run time results from a compiler aggressively optimizing a trivial benchmark.
Performing objdump -S with debugging information turned on yields
000000ac <cpu_execute_event>:
  ac:   e3003000    movw    r3, #0
  b0:   e3403000    movt    r3, #0
  b4:   e16d42f4    strd    r4, [sp, #-36]! ; 0xffffffdc
  b8:   e5930000    ldr r0, [r3]
  bc:   e1cd60f8    strd    r6, [sp, #8]
  c0:   e1cda1f8    strd    sl, [sp, #24]
  c4:   e3a0b000    mov fp, #0
  c8:   e35b0000    cmp fp, #0
  cc:   e1cd81f0    strd    r8, [sp, #16]
  d0:   e58de020    str lr, [sp, #32]
  d4:   03500003    cmpeq   r0, #3
  d8:   ed2d8b04    vpush   {d8-d9}
  dc:   e24dd004    sub sp, sp, #4
  e0:   9a00002a    bls 190 <cpu_execute_event+0xe4>
  e4:   ed9f9b35    vldr    d9, [pc, #212]  ; 1c0 <cpu_execute_event+0x114>
  e8:   e1a0a000    mov sl, r0
  ec:   e3a06003    mov r6, #3
  f0:   e3a07000    mov r7, #0
  f4:   e2966001    adds    r6, r6, #1
  f8:   e2a77000    adc r7, r7, #0
  fc:   e157000b    cmp r7, fp
 100:   0156000a    cmpeq   r6, sl
 104:   0a000021    beq 190 <cpu_execute_event+0xe4>
 108:   e1a00006    mov r0, r6
 10c:   e1a01007    mov r1, r7
 110:   ebfffffe    bl  0 <__aeabi_ul2d>
 114:   ec410b10    vmov    d0, r0, r1
 118:   eeb50b40    vcmp.f64    d0, #0.0
 11c:   eeb18bc0    vsqrt.f64   d8, d0
 120:   eef1fa10    vmrs    APSR_nzcv, fpscr
 124:   4a000022    bmi 1b4 <cpu_execute_event+0x108>
 128:   eeb48bc9    vcmpe.f64   d8, d9
 12c:   eef1fa10    vmrs    APSR_nzcv, fpscr
 130:   baffffef    blt f4 <cpu_execute_event+0x48>
      if (c % l == 0)
 134:   e2068001    and r8, r6, #1
 138:   e3a09000    mov r9, #0
 13c:   e1983009    orrs    r3, r8, r9
 140:   0affffeb    beq f4 <cpu_execute_event+0x48>
 144:   e3a04002    mov r4, #2
 148:   e1a05009    mov r5, r9
 14c:   e2944001    adds    r4, r4, #1
 150:   e2a55000    adc r5, r5, #0
 154:   e1a00004    mov r0, r4
 158:   e1a01005    mov r1, r5
 15c:   ebfffffe    bl  0 <__aeabi_ul2d>
 160:   ec410b17    vmov    d7, r0, r1
      if (c % l == 0)
 164:   e1a02004    mov r2, r4
 168:   e1a03005    mov r3, r5
 16c:   e1a00006    mov r0, r6
 170:   e1a01007    mov r1, r7
 174:   eeb47bc8    vcmpe.f64   d7, d8
 178:   eef1fa10    vmrs    APSR_nzcv, fpscr
 17c:   8affffdc    bhi f4 <cpu_execute_event+0x48>
      if (c % l == 0)
 180:   ebfffffe    bl  0 <__aeabi_uldivmod>
 184:   e1923003    orrs    r3, r2, r3
 188:   1affffef    bne 14c <cpu_execute_event+0xa0>
 18c:   eaffffd8    b   f4 <cpu_execute_event+0x48>
 190:   e3a00000    mov r0, #0
 194:   e28dd004    add sp, sp, #4
 198:   ecbd8b04    vpop    {d8-d9}
 19c:   e1cd40d0    ldrd    r4, [sp]
 1a0:   e1cd60d8    ldrd    r6, [sp, #8]
 1a4:   e1cd81d0    ldrd    r8, [sp, #16]
 1a8:   e1cda1d8    ldrd    sl, [sp, #24]
 1ac:   e28dd020    add sp, sp, #32
 1b0:   e49df004    pop {pc}        ; (ldr pc, [sp], #4)
 1b4:   ebfffffe    bl  0 <sqrt>
 1b8:   eaffffda    b   128 <cpu_execute_event+0x7c>
 1bc:   e320f000    nop {0}
 1c0:   00000000    .word   0x00000000
 1c4:   40000000    .word   0x40000000
which doesn't have any divide instructions or equivalent subroutine calls [Edit: Actually it does. At address 180 there is a call to __aeabi_uldivmod as pointed out below. This is also not so surprising, because the binary I created doesn't run any faster than the usual Raspbian one].
dom
Mon Sep 16, 2019 9:38 pm
which doesn't have any divide instructions or equivalent subroutine calls.
bl 0 <__aeabi_uldivmod> ?
ejolson
Mon Sep 16, 2019 9:48 pm
Hm. I must be blind. It seems I missed that. So why is it running so fast? [Edit: Okay, the version I compiled isn't running fast. What's going on with the claim that -mcpu=cortex-a72 makes sysbench run fast in 32-bit mode?]
jdonald
Tue Sep 17, 2019 5:56 pm
Your analysis is solid.
I've spent some time playing around with that same sysbench build environment from last month, and whatever I thought I saw then is not reproducible. It seems clear now that adding -march=armv8-a helps the arm-linux-gnueabihf compiler emit udiv instructions for 32-bit division, but does nothing for 64-bit division benchmarks like sysbench --test=cpu.
At this point the only way I imagine achieving such speedup in 32-bit--without modifying the C code--would be if the compiler deduced from max_prime being a 32-bit unsigned int that it could use 32-bit values for c and l. Neither clang nor gcc is clever enough to do this, and I'm pretty sure I only tested gcc 8.3.0 at the time anyhow.
ejolson
Fri Sep 20, 2019 7:51 pm
I've been building my own versions of gcc version 9.2 in an attempt to figure out what is going on. I made two builds: One with the flags
../gcc-9.2.0/configure -v --enable-languages=c,c++,fortran \
    --prefix=/usr/local/gcc-9.2-v6 --enable-shared --disable-multilib \
    --enable-threads=posix --disable-browser-plugin \
    --with-arch=armv6 --with-fpu=vfp --with-float=hard \
    --build=arm-linux-gnueabihf --host=arm-linux-gnueabihf \
    --target=arm-linux-gnueabihf --enable-checking=release
and the other with the flags
    --prefix=/usr/local/gcc-9.2-v8 --enable-shared --disable-multilib \
    --with-arch=armv8-a+crc+simd -with-tune=cortex-a72 \
    --with-fpu=neon-fp-armv8 --with-float=hard \
Then I compiled two versions of sysbench one with each of the compilers.
export CC=/usr/local/gcc-9.2-v6/bin/gcc
export CFLAGS="-march=armv8-a+crc+simd -mtune=cortex-a72 -mfpu=neon-fp-armv8"
./configure --prefix=/home/ejolson/sysbench-v6 --without-mysql
make clean
make -j4
make install
and again with
export CC=/usr/local/gcc-9.2-v8/bin/gcc
./configure --prefix=/home/ejolson/sysbench-v8 --without-mysql
make clean
make -j4
make install
Note that the compiler flags passed to the sysbench configure script are the same in each case and explicitly specify the armv8-a+crc+simd architecture. Moreover, the generated assembler code as verified by objdump -S for the cpu_execute_event routine is exactly the same using either build of the gcc 9.2 compiler. Performance of the resulting sysbench programs, however, was notably different.
MAX PRIME   gcc-9.2-v6   gcc-9.2-v8   RATIO
20000         139.41      371.7357    2.666
200000          4.97       15.41      3.101
Again, I would emphasize that the compiler flags used to build both versions of sysbench explicitly specified the armv8 architecture with cortex-a72 tuning and the actual assembler code produced by either compiler was exactly the same.
I suspect the three-times performance increase results from the support library that implements __aeabi_uldivmod. In the case of the compiler that was built for ARMv8 running in 32-bit mode, this library may use the 32-bit sdiv and udiv divide instructions to implement a slow 64-bit division; the compiler built to be reverse compatible with ARMv6 likely uses an even slower algorithm.
Moving forward, as this support library is not huge, it would make sense to include both in the default Raspbian install and select the correct one based on which ARM processor is being used. I find it a bit surprising that this doesn't already happen automatically.
