Sat Aug 03, 2019 4:58 am
chuUK wrote:
Sat Aug 03, 2019 2:41 am
It's true: the latest Pi4 isn't quite as cheap as it is being made out. As mentioned above, the board £55, Power £8, fan £10, MicroHDMI 2 X £5, SD card £8. Definitely pushing close to £100.
Don't forget the 2x4K monitors, network cable (if not using wifi), case, keyboard, mouse, assorted USB devices, desk and a building to house it in ;-)
All I had to buy was the Pi, one microHDMI cable and a microUSB to USB-C adaptor for power. I'm not even using the microHDMI cable at the moment as all my Pi run headless.
The other unseen costs are time and loss of earnings. Raspbain - while very good - doesn't hold a candle to Mint (which is still pretty XP-like).
XP? Urgh :(
Raspbian (note spelling) is pretty good. I've had very few problems with it.
Have my Pis cause loss of earnings? No. Possibly the opposite, although I'd like to do more there.
Loss of time? Yes, because I've had so much fun working on them :-)
We do love the noticeably cheaper electricity bill after switching from 8 desktop PCs. Also, savings on air-con and much much quieter office now we don't have that low-level hum we did from the PCs before.
Yes. I used to have a few PCs around my house running 24/7 and burning electricity. They have all been replaced by various Pis and saving me a fortune, plus the Pi 1B that controls my heating saved it's cost in a few months.
Unreadable squiggle
davidcoton
Sat Aug 03, 2019 9:35 am
32-bit is a massive shame - I know your reasons but even so.
I think you, and other like-minded contributors, are going to be massively disappointed when 64-bit OSs become available (probably 3rd party ones before Raspbian). Except in certain niche applications, there simply is no massive performance gain.
Signature retired
k-pi
Fri Aug 09, 2019 10:06 am
Haven't posted in a while - so - is EDID recognition fixed yet, & what about USB booting? - (neither was working in the 10/7/19 Raspbian download).
Fri Aug 09, 2019 10:29 am
EDID. Much improved, but still some issues with some EDID's. Worth noting that most monitors work fine and have done since launch.
USB Boot. No change.
chuUK
Sat Aug 10, 2019 8:23 am
XP? Urgh :(
Good that u had to get so little to get the Pi running. But that will not be the case for many buyers. We had no spare MicroSD's lying around. Nor 8 shim fans which you HAVE to use if you want to use this as a working desktop And we didn't have the power adaptors either.
Rasp-bane would be a better spelling. But after 6 weeks we have worked out its XP-like nature - don't tell me it's not!
Loss of earning: Again, nice for you. Maybe you are Super PiMan and nothin can touch you. Congrats. For us mere mortals, my department has lost earnings over the last 6 weeks. A degree of loss was calculated as we were moving platform, but nowhere near what we had happen.
The Pi tinkering stuff is fab. But the 4 is also aimed at me and my market in a way previous models were not able to be. When the bugs have been ironed out, the idea of the 4 as an office/low-end creative computer is a little revolution.
From my experience, day-to-day office is almost all web-apps. All their computer really needs to do is run Chromium. It's a huge market. I looked at replacement PCs for around £400 for i5. The Pi with all the bits (including second SD card or USB3 stick to image the OS just in case that package you installed borks the system) is around £100. A significant saving and much lower running costs.
jahboater
Sat Aug 10, 2019 8:32 am
No you do not HAVE to.
My Pi4 which is my desktop and software development platform, runs very happily without one.
Never throttles under any load.
pica200
Sat Aug 10, 2019 9:31 am
No, you don't have to use fans but they are needed if you don't want burned Pi(e) :P More heat average means less lifetime so it's a good investment having any form of extra cooling. A heatsink case will do too. No case at all works but you will definitely reach throttling temps with that if you have any higher CPU load.
jahboater
Sat Aug 10, 2019 9:45 am
Check for throttling with:
vcgencmd get_throttled
after running a typical workload.
If it says 0x0 then you have had no thermal problems or power supply problems while running your task.
The Pi4 like the older Pi3B+ uses the copper ground plane (and metal sockets) of the PCB as a built-in heat sink. It also uses a 28nm node size down from 40nm for the Pi3
In the UK, all four CPU cores maxed out raised the temp from 54C at idle to 68C after about ten minutes.
That's with NO fan! With a full desktop running and a few web browser tabs.
Heavy use of NEON will make it hotter (see the cpuburn stress test).
bensimmo
Sat Aug 10, 2019 10:46 am
Which is the complete opposite to me where Chromium takes it up to 80c and throttles without a fan blowing gentle air over it. Many people see this, you're lucky.
HawaiianPi
Sat Aug 10, 2019 11:19 am
Complete nonsense!
Pi computers thermally throttle to protect themselves from overheating. You might get slower performance, but you won't get burned Pi(e) :roll:
Mikael
Sat Aug 10, 2019 1:17 pm
My Pi 4 runs at around 60C idle on the Raspbian desktop. Ambient maybe 24C. A simple compile job on all four cores had me throttling in maybe 2 minutes. This was in the official case, but with the top off. I know it won’t hurt the board, but it still shows throttling will occur even when doing pretty basic stuff.
pica200
Sat Aug 10, 2019 1:23 pm
Fine, let's agree on cooked Pi(e) :P
It was a joke in case you did not get it ;)
edit:
No problems here with heatsink case. Even with cpuburna53 it's max 68°C. Official USB-C power supply.
jahboater
Sat Aug 10, 2019 1:28 pm
Many people who put them in small plastic cases see this ....
jahboater
Sat Aug 10, 2019 1:29 pm
Try taking it out of the official case. I find mounting it on edge, for the best convection airflow, has a small advantage too.
Sat Aug 10, 2019 1:36 pm
This is not true. The throttling ensures that temperatures that will damage to Pi do not occur. And the temperature at which they will damage enough to cause a life time problem - over 120degs.....
I use a Pi4, no case, no fan, no heatsink. Works fine for my use case. Doesn't throttle.
pica200
Sat Aug 10, 2019 1:48 pm
And the SoC may be fine up to 120°C but it causes stress to surrounding components aswell. And the solder balls under it which is the reason many cheap laptops with bad cooling fail early ;)
jahboater
Sat Aug 10, 2019 3:20 pm
You will find the Raspberry Pi is rather better engineered than that.
In fact the SoC is deliberately thermally coupled to the copper board back plane, giving the Pi as a whole considerable thermal inertia.
bensimmo
Sat Aug 10, 2019 3:51 pm
of which i have none.
pica200
Sat Aug 10, 2019 4:12 pm
I have not tried without the case but with the crap thermal pad supplied with the case it was 49-51°C idle and 78-80 with cpuburna53. After replacing it's now 46-47 idle and max 68 under load. I would probably see the same 51-55°C without anything and throttling under heavier load.
I know the ground planes of the whole board will sink heat away but that's not enough to prevent throttling. Especially if i'm gonna fire up gcc or similar ;)
jahboater
Sat Aug 10, 2019 4:18 pm
Don't worry about GCC!
A 13,000 line compilation, with optimization, raises the temp of my Pi4 by 2C.
Compiling GCC itself which is huge, using make -j5 (all four cores flat out for over 3 hours) did not reach throttling or even close. That's roughly 54 million lines of code.
No fan needed of course, just give it some free air ventilation.
jahboater
Sat Aug 10, 2019 4:21 pm
Its enough for shortish jobs (that's what thermal inertia means). Perhaps a couple of minutes.
MisterEd
Sat Aug 10, 2019 10:20 pm
My Pi 4 4GB used to throttle a lot. I knew because the thermometer icon would pop up a lot. After I installed it in a Flirc case it would idle about 38C but would never go above 60C no matter how hard I pushed it.
I added a couple useful items to the Panel.
Temperature Monitor (show temperature in degrees C)
CPU Usage Monitor (show usage as percentage)
NetSecond
Sun Aug 11, 2019 1:06 am
When will USB Boot and PXE coming ??
Gruß / Regards
NetSecond
Gavinmc42
Sun Aug 11, 2019 1:12 am
Net booting in a month or so USB boot after that.
That's in the blog interview video
I'm dancing on Rainbows.
gubo1
Sat Aug 17, 2019 2:24 pm
any news on when the new revision (usbc power quirk fixed) will be out?
