geffers
Temporary Router
Sat Jun 15, 2019 11:06 am
Folks,
Curious, I have a number of devices working behind a router, it is an old router and the admin page shows some kind of throughput (blocks) but no real detail.
Is there any way of routing (temporarily preferably) all network traffic through a Pi so that using something like ntopng more detailed network traffic can be viewed.
Appreciate this could cause a bottleneck, hence suggestion of temporary.
Geoff
epoch1970
Re: Temporary Router
Sat Jun 15, 2019 11:43 am
I'd rather suggest adding a bridge (possibly anonymous = sans IP address), in other words turn the Pi into a 2-port ethernet switch, that will see all the traffic pass through it without changing anything to the network setup.
For ethernet:
  • Install on the Pi the software packages you want to use,
  • Add an USB adapter to the Pi,
  • Create a bridge br0 with both eth0 and usb0 in it,
  • Disconnect everything from the router except WAN and one LAN cable,
  • Stick the LAN cable in the Pi,
  • Connect another cable from the USB adapter to a switch on which LAN clients are connected.
So for this recipe you need: 1 gigabit USB adapter, 1 ethernet switch, 1 ethernet cable, Pi and accessories.
If you need to see wifi traffic as well, altering the router, and possibly clients configs will be required:
  • Disable the AP in the router,
  • Create one with possibly identical parameters in the Pi,
  • Add wlan0 to the bridge.
Ethernet or wifi, performance will suffer so the setup is not going to be as "transparent" as it can be.
tpylkko
Sat Jun 15, 2019 1:46 pm
On many routers you can install a linux-based open source firmware that then allows you to modify and install almost anything on them.
Andyroo
Sat Jun 15, 2019 2:09 pm
The best known is https://dd-wrt.com/ but there is https://openwrt.org/ and https://advancedtomato.com/ with different capabilities.
geffers
Mon Jun 17, 2019 12:47 pm
Yes, I've seen them, my present Router is old but still works fine and can't take that firmware update.
Thanks for suggestion.
Geffers
geffers
Mon Jun 17, 2019 12:49 pm
Great suggestion but for my minimal requirements might be too much.
Think I may just go with installing ntopng on remote machine then just viewing nia web browser.
Geffers
procount
Mon Jun 17, 2019 12:51 pm
Lede / Openwrt can also be installed on a RPi to turn it into a router. It's available for many devices. (also installable via PINN ;) )
geffers
Mon Jun 24, 2019 2:09 pm
Now the Pi 4 is out with gigabit ethernet this becomes a decent option.
Geffers
