Xenon85
CPU1 fail to come online
Fri Jun 14, 2019 9:43 am
Good day.
I have the said error message on my Raspberry Pi
I've already made the latest Rasbian version on a new SD card using Etcher. Same mistake.
What solve the problem?
Re: CPU1 fail to come online
Fri Jun 14, 2019 9:55 am
If you see that on a new SD card, I would suspect broken hardware. I've never seen that error before!
Xenon85
Fri Jun 14, 2019 11:01 am
broken Pi or broken SD card?
Andyroo
Fri Jun 14, 2019 11:12 am
There are a few notes on other ARM forums where this is due to a power issue - specifically a timing issue at start up.
Is the Pi a CM and you are using your own power supply?
Xenon85
Fri Jun 14, 2019 11:37 am
what do you mean with CM? I use the included power adapter
Andyroo
Fri Jun 14, 2019 11:55 am
Is it a compute module?
If not what type of Pi is it and what is the power supply?
Xenon85
Sat Jun 15, 2019 3:53 am
It's a Raspberry PI 3 B + and the power adapter is a 5 Volt with 3A
https://www.amazon.de/gp/aw/d/B078567K8 ... UTF8&psc=1
