KRolander
CMOS Technology on BCM2837
Thu Jun 13, 2019 8:45 am
Hi all,
Does anyone know what type of CMOS transistor technology is used in BCM2837 (Raspberry Pi 3 B) ? Especially it's would be great to know what is the size of CMOS transistor (in nm). :geek:
Thank You
Best Regards
KRolander
rpdom
Re: CMOS Technology on BCM2837
Thu Jun 13, 2019 8:57 am
I don't know the transistor type, but it is 40nm size.
Unreadable squiggle
drgeoff
Thu Jun 13, 2019 2:38 pm
That is not strictly accurate. 40nm feature size does not mean the transistors are 40 nm.
http://vlsi-soc.blogspot.com/2014/06/fe ... stors.html
https://electronics.stackexchange.com/q ... length-and
https://en.wikichip.org/wiki/technology_node
Quis custodiet ipsos custodes?
dl324
Thu Jun 13, 2019 2:53 pm
It's unlikely that they only used one transistor size. The smallest transistors will be in the memory array and they're typically smaller than any logic transistors because the array is very regular and they can optimize topology for any process node.
KRolander
Tue Jun 25, 2019 8:10 am
Thank You for these infos ! ;)
