andysilch
Dragino LoRa GPS HAT
Tue Jun 11, 2019 10:42 am
I have just installed a Dragino LoRa/GPS HAT and followed the instructions on their website for GPS for setting up /dev/ttyS0.
https://wiki.dragino.com/index.php?titl ... _3_Model_B
It works mostly, but I am very surprised at the amount of mis detected characters. I would say about 30% of all GPS statements are unreadable, perhaps more.
I was using a U-blox7 USB GPS previously and never had a problem.
I have downloaded the device tree and put the following in to /boot/config.txt
dtparam=spi=on
dtoverlay=pi3-disable-bt-overlay
core_freq=250
enable_uart=1
force_turbo=1
I was not sure about the force_turbo = 1, so I tried it without first of all. It seems to make no difference.
I see that the website was last updated 2 years ago. Does anyone know if these instructions are still valid? Anyone have success with this HAT?
I have just started to use the LoRa side and it mostly (again) seems OK. I am using hackrf_transfer to replay the sender messages. This seems OK but if I leave it the HAT on receive and it picks a some random noise which it decodes with multiple garbled characters, from then on it will not decode any messages successfully from the hackrf_transfer. This could be a bug in their sender / rec code but I have not looked at this yet.
Ta, Andy.
