I'm working with Raspberry Pi Zero W. I SSH to it via micro USB without problem, as described in this manual:
https://www.thepolyglotdeveloper.com/20 ... cable-ssh/
Now, I connected a ZERO4U to it for more USB connections.
When I am connected to it via WIFI, it works, and the USB ports also work.
However, when I connect it to my PC (either via the original micro-USB on the Pi Zero or the mini-USB on the ZERO4U) it show the message:
"USB device not recognized".
The problem goes away when I remove the ZERO4U.
Is this fixable? I must be able to SSH to it via USB, so wireless workarounds are unfortunately not relevant.
