script problem (again) - scratching my head...
Posted: Wed Jun 05, 2019 9:35 pm
by Bosse_B
I am trying to write a file copy script to handle video uploads to my Kodi media centers.
I want to tell my script to upload to my website (this works fine) and to none, one or both media centers using a second parameter.
This is the relevant part of my script dealing with this:
#/bin/bash
# Read command line arguments
if [ -z "$1" ]; then
echo "Please enter an existing file name as arg 1!"
echo "Usage:"
echo "putvideo <video filename> <target mediacenters>"
exit
else
FILENAME="$1"
if [ ! -f "$FILENAME" ]; then
echo "File $FILENAME not found!"
exit
fi
fi
if [ -z "$2" ]; then
kodiflag="$2"
else
kodiflag="0"
fi
#Now copy files to Kodi (only if flag is set)
if [ "$kodiflag" = "1" ] || [ "$kodiflag" = "3" ]; then
echo "Copy the video file to Kodi"
COMMAND="cp $FILENAME $KODIDISK/$DIRNAME/"
$COMMAND
fi
if [ "$kodiflag" = "2" ] || [ "$kodiflag" = "3" ]; then
echo "Copy to new Kodi too"
COMMAND="cp $FILENAME $KODIDISK2/$DIRNAME/"
$COMMAND
fi
But calling this script using parameters like this:
results in no copy at all even though I expected the first if to trigger...
Apparently the logic (assembled from reading posts via Google search) does not work but I don't know why...
Any ideas?
Re: script problem (again) - scratching my head...
Posted: Thu Jun 06, 2019 1:20 am
by swampdog
#!/bin/bash
^^^ no ! (bang) in yours.
kodiflag="$2"
^^^if nul then set nul?
I tend to use the same basic template..
#!/bin/bash
NAM=`basename "$0"`
fcp_usage ()
cat<<EOF
${NAM}: [ --help | -h ]
${NAM}: [ start | 1 ]
${NAM}: [ stop | 0 ]
${NAM}: [ foo ] [arg1] [arg2]
EOF
fcp_1 ()
echo "activate something"
fcp_0 ()
echo "deactivate something"
fcp_foo ()
[ $# -lt 2 ] && {
fcp_usage 1>&2
exit 1
echo "$@"
fcp_main ()
case "$1" in
start | 1)
fcp_1
stop | 0)
fcp_0
foo)
shift
fcp_foo "$@"
fcp_usage 1>&2
exit 1
esac
case "$1" in
--help | -h)
fcp_usage
exit 0
fcp_main "$@"
esac
It lends itself to quick modification..
#!/bin/bash
NAM=`basename "$0"`
KODIDISK=("/tmp/one" "/tmp/two")
fcp_usage ()
cat<<EOF
${NAM}: [ video filename ] [ target mediacentre ]
EOF
fcp_cp ()
echo cp "$@"
fcp_main ()
local filename="$1"
local kodiflag="$2"
[ -z "$filename" ] || [ ! -f $filename ] && {
echo "$NAM: No filename!" 1>&2
fcp_usage 1>&2
exit 1
if [ 1 == $(( kodiflag & 0x01 )) ]
then
fcp_cp "$filename" "${KODIDISK[0]}"
fi
if [ 2 == $(( kodiflag & 0x02 )) ]
then
fcp_cp "$filename" "${KODIDISK[1]}"
fi
case "$1" in
--help | -h)
fcp_usage
exit 0
fcp_main "$@"
esac
Hope that helps.
Posted: Thu Jun 06, 2019 8:29 am
by hortimech
Very nice changes, but it isn't portable, what if the OP is using dash ? The first problem that would be hit is that dash doesn't use arrays
Try this instead:
#!/bin/bash
NAM=$(basename "$0")
KODIDISK1="/tmp/one"
KODIDISK2="/tmp/two"
fcp_usage ()
cat<<EOF
EOF
fcp_main ()
local filename="$1"
local kodiflag="$2"
[ -z "$filename" ] && {
fcp_usage 1>&2
exit 1
[ ! -f "$filename" ] && {
echo "$NAM: Incorrect filename!" 1>&2
fcp_usage 1>&2
exit 1
if [ 1 = $(( kodiflag & 0x01 )) ]; then
cp "$filename" "${KODIDISK1}"
fi
if [ 2 = $(( kodiflag & 0x02 )) ]; then
cp "$filename" "${KODIDISK2}"
fi
case "$1" in
--help | -h)
fcp_usage
exit 0
fcp_main "$@"
esac
[?code]
Posted: Thu Jun 06, 2019 7:54 pm
by Bosse_B
swampdog wrote: ↑Thu Jun 06, 2019 1:20 am
#!/bin/bash
Didn't notice. Several of my scripts have this error but work anyway
kodiflag="$2"
Oh Gosh!
it should have been:
kodiflag="0"
else
kodiflag="$2"
fi
Hope that helps.
I think you spotted two of my bugs.
I am now on a location where the Kodi boxes are not reachable so I will have to test some other way.
Back latest on Sunday.
Posted: Thu Jun 06, 2019 9:57 pm
by swampdog
@hortimech
#!/bin/dash ?
Shell script portability is a nightmare because you're reduced to using bourne shell (aka #!/bin/sh) and once you get complex enough to be pulling in sub scripts it becomes a royal pita. There's so many pitfalls that its either best (a) not to bother (b) install the same shell across all systems. eg:
admin@pi05:/wrk/T $ file `which sh`
/bin/sh: symbolic link to dash
..which seems innocuous but opens a can of worms as you're running dash in 'sh' mode and there'll be subtle differences between it and systems which implement a standalone /bin/sh like the BSD's and Aix. We haven't even touched on command differences - "ps -ef" on bsd is not the same as on linux.
Posted: Thu Jun 06, 2019 10:14 pm
by ShiftPlusOne
Hope this doesn't derail the thread, but I'd just like to suggest 'shellcheck', which is a brilliant tool that finds most of the mistakes people make in shell scripts, including portability issues.
Posted: Fri Jun 07, 2019 6:58 am
by hortimech
Yes , I always run my scripts through shellcheck, that's why it was '/bin/dash', I suppose I could have used '/bin/sh' instead, the result would have been the same, the suggested script wasn't portable.
Why did I set it to '/bin/dash' ?
Just to test the script, my default shell is '/bin/bash' so 'as is' the script had a few problems (backticks are so last year etc), but change the shebang to '/bin/dash' and shellcheck tells you that arrays are a no-no
If it was a complex script, then using arrays may have been needed, but it was such a simple script, that they were not needed.
Posted: Fri Jun 07, 2019 10:40 pm
by Bosse_B
hortimech wrote: ↑Fri Jun 07, 2019 6:58 am
No such command on RPi2, RPi3 nor Ubuntu18...
So must be installed.
Is it worth it for a very casual scripter?
Posted: Sat Jun 08, 2019 6:53 am
by hortimech
Well, no and yes
You don't actually need it, if your script works for you, then you are okay without it, but if you want to learn how to use shell script better, then it can point you to any errors.
Posted: Fri Jun 14, 2019 8:23 pm
by swampdog
'shellcheck' does look quite useful. I'm amazed I've gone all these years without knowing of it. It can't do any harm to run it and because you can disable warnings to taste you can see the wood for the trees. In my case, SC2006, depreciated backticks rather than $(..), and it's not to know I deliberately don't quote variables which hold numbers.
