Jirka99
Low SD card space
Fri May 31, 2019 9:51 am
On my Raspebbry 2 with SD 16GB is only about 3GB left. I don't install any apps. The basket is empty. Which folder should I look at? Thank you.
RaTTuS
Re: Low memory
Fri May 31, 2019 9:59 am
sudo fdisk -l
df -h
Covfefe
DarkPlatinum
Contact: Website YouTube
Re: Low memory
Fri May 31, 2019 10:03 am
Did you expand the filesystem?
(Topic name should be changed to something more relevant)
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3 1 * Raspberry Pi 3B + :mrgreen:
Check Out My Raspberry Site (Run on a Raspberry Pi 3B :) ): https://html.dynu.net
jahboater
Re: Low memory
Fri May 31, 2019 10:10 am
The du command (disk usage) is useful (see "man du")
du -h . | sort -rn | more
prints a list of the sub directories in reverse order of size
Moonmarch
Re: Low SD card space
Fri May 31, 2019 10:25 pm
When you empty the trash can, the files can be stored in a folder in a different directory instead of being deleted completely, which is still using space on the memory card, you can find the folder in the /home/pi/.local/share/Trash/expunged directory, if you can't delete the folders or the content with the trash can, you need to delete the files using the rm command:
cd /home/pi/.local/share/Trash/expunged
sudo rm -R "folder name"
Milliways
Sat Jun 01, 2019 12:29 am
sudo du -h -d1 /
Will show the usage of each top level directory.
My system includes
4.8G	/usr
2.2G	/home
1.2G	/opt
You can then drill down into the larger directories to explore further e.g.
sudo du -h -d1 /opt
shows Wolfram is using most of the space
