Re: Is the FAQ image accurate?
Posted: Wed Jan 18, 2012 12:09 am
by jwatte
Is the FAQ image of the board accurate? Specifically, dimensions, and placement of components? I might want to work out some gcode to generate a RPi case out of any solid material (Ebenholz, Brass, Delrin, ...)
Posted: Wed Jan 18, 2012 12:11 am
by liz
No, it's a diagram (which was designed before we even had betas) which is not to scale; it's to demonstrate where the ports are and what the different bits on the board do to non-technical people. (It's designed by Paul Beech, who is also behind our logo, and it's been very useful for that purpose; you may have seen it reproduced in a number of newspapers.)
If you're building cases, there are measurements that Gert has taken with some Vernier callipers at
http://www.raspberrypi.org/forum/projec ... nical-data – note that until we get production boards back these are not absolutely set in stone, because things may change in manufacture.
Posted: Sun Jan 22, 2012 8:03 am
by jwatte
Thanks for the link!
I'm thinking a varnished ebony case would be nice. Or maybe a case milled out of solid plexiglas...
