thangvc91
Help using github with Pi3B+
Fri May 24, 2019 9:32 am
Hi everyone,
I found this article when trying search how to renew DNS on noip.
https://github.com/loblab/noip-renew
But i don't know how to use it, Can anybody help guide me process/principle to use it ? Sorry if my question is bad.
I saw the usage as below:
Usage
Set your noip.com account info and number of hosts in noip-renew.sh,
Run setup.sh,
Run noip-renew.sh, check result.png (if succeeded) or error.png (if failed)
For docker users, check Dockerfile, docker-compose.yml, crontab-docker-host.
Check confirmed records from multiple log files:
grep -h Confirmed *.log | grep -v ": 0" | sort
1 - download it as zip then extract
2 - configure my account on no-ip in appropriate file ? right ?
In case , if i would like to use docker , could you help me about the progress ?
