okenido
Atmega328p + RPI : ICSP programming providing 3.3V
Sun May 19, 2019 1:25 pm
I made a circuit which uses a raspberry pi and an atmega328p microcontroller, which gets its power from rpi's 3.3V pin. I added an ICSP header so we can program the microcontroller directly on board after everything was assembled.
Normally, I would program it before connecting the raspberry pi, but if for some reason it is connected, can this be harmful for the raspberry pi ? (we're talking about providing 3.3V though the header pin while everything else is NOT powered -- the raspberry doesn't get its main 5V input)
AdamStanislav
Contact: YouTube
Re: Atmega328p + RPI : ICSP programming providing 3.3V
Sun May 19, 2019 3:20 pm
You have lost me there. If the RPi does not get its main 5V input, where does the 3.3V output come from?
davidcoton
Sun May 19, 2019 3:26 pm
I would not recommend applying external 3V3 to the Pi GPIO header pin 3V3 under any circumstances, whether ther Pi is powered or not. The pin is designed for providing a 3V3 source; using it as a sink could damage the Pi, probably permanently and completely. The Pi 3B+ (and 3A+?) is particularly sensitive to this, but other models may also suffer.
Signature retired
okenido
Sun May 19, 2019 4:55 pm
sorry, i talk about providing 3.3V unintentionally while programming the Atmega328p through the ICSP header. It's needed to program it, but as a side effect the 3.3V is also going to the raspberry.
How would you protect from that to happen ? A jumper somewhere to cut the 3.3V line between the atmega and the rpi ?
AdamStanislav
Contact: YouTube
Sun May 19, 2019 6:08 pm
Would a diode work?
Brandon92
Sun May 19, 2019 7:06 pm
Here are some options I think:
  • You could program the uc before you solder it onto the board
  • Use a mosfet as a ideal diode.
  • Use a jumper, like you suggested
  • Power the Rpi without the sd card? And use the given 3,3v for programming.
dave j
Sun May 19, 2019 7:09 pm
Have your thought of programming the AVR using the Pi?
Using this page: Using Raspberry Pi as an Arduino (AVR) programmer and information in the Arduino IDE's files I've been able to program Arduino clones that use ATmega32U4. (That page is a bit out of date - the current Raspbian avrdude is built with linuxgpio support.)
To completely reprogram the MCU from scratch I use:
avrdude -p m32u4 -c linuxgpio -F -v -e -U efuse:w:0xcb:m -U hfuse:w:0xd8:m -U lfuse:w:0xff:m
avrdude -p m32u4 -c linuxgpio -F -v -e -U flash:w:Caterina-Leonardo.hex -U lock:w:0x2f:m
The values for efuse, hfuse, lfuse and lock are from the Arduino boards.txt file - you'll need the check the values for your MCU. The Caterina-Leonardo.hex is the Arduino boot loader for the Arduino Leonardo.
