hosseinpink
no connection after cluster and NFS storage setting
Sun May 19, 2019 10:25 am
Hi friends,
I had four Pis and created a cluster.
I also used my flash memory as NFS shared memory among them.
I did not work for a while but after making a ssh connection to master node I got the message error :
"connect to host 10.42.0.87 port 22:no route to host"
I really dont understand this error.
all other worker pis can be connected but the master i got the mentioned error.
Any idea?
Ernst
Re: no connection after cluster and NFS storage setting
Sun May 19, 2019 10:47 am
message error :
I suggest you confirm that you are using the correct IP address.
