the_andyman12
apt is broken and cant find any solutions
Fri May 17, 2019 5:20 am
my apt is broken and I have been searching for answers for several hours on how to reinstall it. I have a raspi 3
and here are the errors I get.
if i do
sudo apt-get update
i get
apt-get: error while loading shared libraries: liblz4.so.1: cannot open shared object file: No such file or directory
I have tried t reinstall it but when I do
sudo dpkg -i --auto-deconfigure apt_1.8.1_armhf.deb
I get
(Reading database ... 123197 files and directories currently installed.)
Preparing to unpack apt_1.8.1_armhf.deb.1 ...
Unpacking apt (1.8.1) over (1.8.1) ...
dpkg: dependency problems prevent configuration of apt:
 apt depends on libapt-pkg5.0 (>= 1.7.0~alpha3~); however:
  Package libapt-pkg5.0:armhf is not configured yet.
 apt depends on libgnutls30 (>= 3.6.6); however:
  Package libgnutls30 is not installed.
 apt depends on libseccomp2 (>= 1.0.1); however:
  Package libseccomp2 is not installed.
 apt depends on libstdc++6 (>= 5.2); however:
  Version of libstdc++6:armhf on system is 4.9.2-10+deb8u1.
dpkg: error processing package apt (--install):
 dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.19-18+deb8u10) ...
Processing triggers for man-db (2.7.5-1~bpo8+1) ...
 apt
the_andyman12
Re: apt is broken and cant find any solutions
Fri May 17, 2019 6:48 pm
NVM I just wiped my rasberripi and reinstalled the whole thing
gkaiseril
Fri May 17, 2019 7:35 pm
You could have tried aptitude, even from the command line, to update , upgrade and install packages.
I would suspect that the specific library that caused the failure could have been down or there could have been a filter blocking your access to it.
Many times I have found waiting some hours or even days or changing network connections clears the issue.
Have you made any changes to the repository list?
