irantxu
Execute Java code with inputs
Fri May 10, 2019 2:40 pm
Good afternoon,
I was trying to execute an easy Java program (SalsaHoy.java) which requires an input in my Raspberry PI 3 b+, and I was wondering what is the command I should write in order to introduce the input.
The java program is the following one:
public class SalsaHoy(String dia){
if (dia == "Weekend") {
System.out.println("Hay Salsa! :)");
else {
System.out.println("No hay Salsa! :(");
And the commands I have executed in the Raspberry Pi terminal window are the following ones, but I don't know how to introduce the input properly, I receive an error:
cd Java
javac SalsaHoy.java (Weekend)
java SalsaHoy (Weekend)
Thank you in advance for your help
knute
Re: Execute Java code with inputs
Fri May 10, 2019 9:44 pm
Take a look at the java.io.Console class.
