Schorschi
PEN and RUN Pins, Proper Use?
Sun May 05, 2019 11:25 pm
Do I have this right:
PEN when shorted to GND will wake up Pi that is in a halt (or former shutdown state)?
RUN when shorted to GND does a safe reset of the Pi? Safe as in SD card corruption is not an issue?
Read quite a bit of information on this, and the many different references, none seems official. Moreover, why the heck are these locations not pinned via a proper header? It seems their proper use should be encouraged, not discouraged since no header in place?
Last, can't a GND pin next to them not be added in Pi 4 design? Would seem to be a logical and straight forward thing to do?
Imperf3kt
Re: PEN and RUN Pins, Proper Use?
Mon May 06, 2019 12:08 am
The PEN connection wasn't exposed until the Pi3b+
Prior to that model, there was a ground connection in its place.
The next (or later) model Pi is unlikely to revert this change.
55:55:44:44:4C
52:4C:52:42:41
Rose coloured glasses are difficult to see through.
Milliways
Mon May 06, 2019 4:24 am
RUN is actually the SOC Reset pin. It DOES NOT perform a safe shutdown, but can be used to restart the Pi after shutdown.
PEN is the Power ENable pin of the regulator chip - it can be used to put the Pi into a low power state after shutdown; NOTHING to do with wake up - except the Pi will boot when power is applied. The only useful purpose is with external circuitry e.g. solar power etc.
