danielfelix
Flac stream via mpc
Wed May 01, 2019 10:04 pm
Hi friends, I'm trying to play a .flac file hosted on the web that contains about 15 minutes of music.
I do it using pcm add and pcm play
The problem is that it plays normally but at a certain moment, randomly, it is cut, in fact the playlist is cleaned.
If I download the file and reproduce it, there are no problems, it is not cut. That is to say, it is not the file.
I have a good internet connection, I rule out the problem there.
I can not find the why, do you know what may be happening?
If you want to help me and try, I pass more data.
regard
