iTarbuck
Learning to code with Pi.
Sun Apr 28, 2019 4:40 pm
Hi all,
I have just got my new Pi 3b+, and I am looking to learn how to write code.
Where should I be looking, what apps should I be using?
Any help would be greatly appreciated.
Thanks! :D
LTolledo
Re: Learning to code with Pi.
Sun Apr 28, 2019 11:50 pm
For RPi, the "default" is usually coding using python...
Lots of resources at the Programming section of the Forum, go have a peek inside...
Some people be like:
knute
Mon Apr 29, 2019 1:20 am
And the best way to learn how to code is to code! It's like playing a musical instrument, practice, practice, practice...
Mon Apr 29, 2019 5:35 am
iTarbuck,
Open a terminal window on your Pi and type the command "python" and see what happens:
$ python
Python 2.7.13 (default, Sep 26 2018, 18:42:22)
[GCC 6.3.0 20170516] on linux2
Type "help", "copyright", "credits" or "license" for more information.
The ">>>" there is the Python command prompt, an invitation to type in some Python code.
Now type the command 'print ("Hello World")' and see what happens:
Hello World
Cool, isn't it? You have just written a line of Python code and it printed out the message you told it to.
Now try something like:
>>> 3 + 9
12
Even more cool, it does maths for you.
Now try:
>>> a = 3
>>> b = 9
>>> c = a + b
>>> print (c)
12
Far more cool, you can give names to things, "a", "b", "c" in this case. And then do maths using those names.
Those named "variables" also remember things. Just type "c":
>>> c
12
Until you change them again. Try:
>>> c = a * b
>>> print (c)
27
Now for some magic, type this:
>>> if (a < b) : print ("a is smaller than b")
a is smaller than b
Awesome. Python can make decisions. In this case the number "a" is smaller than "b" so it says so.
Make "a" bigger or equal to "b" and will not:
>>> a = 100
There we go. You have now started to lean programming in Python. For further details see google for "python tutorials" and such like.
jahboater
Mon Apr 29, 2019 6:53 am
I suggest using Python3 by the way.
Also pre-installed and ready to use are C and C++ if you would like to try a faster compiled language.
Type this into a file called "hello.c". The nano editor is simple, but any editor of your choice will work fine.
nano hello.c
#include <stdio.h>
int
main( void )
  puts( "hello world!" );
Then compile it:
cc hello.c -o hello
Next run it:
./hello
It should look like this:
[email protected]:~ $ cc hello.c -o hello
[email protected]:~ $ ./hello
hello world!
hello world!
You have made a new command which you can run as many times as you like!
There are many books on C and Python which you can use to learn programming on the Pi.
As said above, the best way to learn is to actually do it!
It costs nothing and you will not hurt the Pi if you make a mistake.
