John50
Change new user privileges
Fri Apr 19, 2019 2:23 pm
I am following some tutorials but it is not clear to me how to give this new user all the privileges that the PI has, the idea is to remove the PI privileges and leave only mine (john) by default.
pi@raspberrypi:~ $ su john
Password:
john@raspberrypi:/home/pi $ sudo visudo
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
[sudo] password for john:
What i need to do next, what is that password [sudo] he is asking?
Re: Change new user privileges
Fri Apr 19, 2019 2:53 pm
That's asking for your userid's login password.
John50
Fri Apr 19, 2019 3:06 pm
Thank you, i notice it.
I just add the new user to the sudo group and after type the [sudo] password for john i can see this, this mean now the john have all the privileges the PI user have right?
# This file MUST be edited with the 'visudo' command as root.
# Please consider adding local content in /etc/sudoers.d/ instead of
# directly modifying this file.
# See the man page for details on how to write a sudoers file.
Defaults env_reset
Defaults mail_badpass
Defaults secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
# Host alias specification
# User alias specification
# Cmnd alias specification
# User privilege specification
root ALL=(ALL:ALL) ALL
# Allow members of group sudo to execute any command
%sudo ALL=(ALL:ALL) ALL
# See sudoers(5) for more information on "#include" directives:
#includedir /etc/sudoers.d
HawaiianPi
Fri Apr 19, 2019 4:07 pm
You should add the new user to all the same groups as the pi user (except the pi group).
To compare groups:
groups pi john
Then add your user john to the same groups (except the pi group).
sudo usermod -G list,of,comma,delimited,groups john
Also, the sudo/password privileges stuff is now stored for users in /etc/sudoers.d
You can either add your user to the default pi user file,
sudo visudo -f /etc/sudoers.d/010_pi-nopasswd
Or create a new file for john.
sudo cp /etc/sudoers.d/010_pi-nopasswd  /etc/sudoers.d/020_john-nopasswd
sudo visudo -f /etc/sudoers.d/020_john-nopasswd
John50
Fri Apr 19, 2019 4:17 pm
To compare groups:
groups pi john
I think I added it already, this is what I see when I execute that command:
pi@raspberrypi:~ $ groups pi
pi : pi adm dialout cdrom sudo audio video plugdev games users input netdev spi i2c gpio
pi@raspberrypi:~ $ groups pi john
john : john sudo
HawaiianPi
Fri Apr 19, 2019 6:14 pm
You just have john in the sudo group. If you only want to interact with the Raspbian OS, that's probably fine. If you want to interact with hardware, you'll need to be in other groups as well. If you want john to be able to do everything pi can do, join all the same groups.
The command, groups pi john, should return:
john : john adm dialout cdrom sudo audio video plugdev games users input netdev spi i2c gpio
John50
Fri Apr 19, 2019 6:27 pm
Yes, that is what i am tiryng to do, I whant the new user has all the same rights as pi user and then removed sudo rights to the PI one.
I am trying to follow few guides but honestly I have not managed to do it.
I apreciate your help.
Andyroo
Fri Apr 19, 2019 6:39 pm
As HW said above:
So you would log on as Pi
Go to the command line
Issue sudo usermod -G adm,dialout john
But put all the groups here with commas.
Let us know how you get on.
John50
Fri Apr 19, 2019 6:54 pm
As HW said above:
So, on the pi user i need to use this command:
And then look for this line:
And add there all this words separated by commas in the same order:
It is correct this way?
Andyroo
Fri Apr 19, 2019 7:27 pm
The order does not matter - but the command will replace any groups the user is a member of!
The way the command is structured is:
sudo <- Run this as super user who can do most things
usermod <- The command to modify something to do with a user
-G <- say you want to give membership to the list of groups ONLY for the user
sadm,dialout <- the list of groups (one or more) NO spaces and with a comma in between each group
john <- the user you wish to change
So
sudo usermod -G sadm john
Followed by
sudo usermod -G dialout john
would leave john as a member of dialout only.
HawaiianPi
Fri Apr 19, 2019 10:17 pm
Assuming you've already added your user with,
sudo adduser john
Then add that user to all the default groups with,
sudo usermod -G adm,dialout,cdrom,sudo,audio,video,plugdev,games,users,input,netdev,spi,i2c,gpio john
Which puts john in all the same groups as the pi user.
Double-check with,
groups pi john
Which should return what I posted previously (all the same groups, except the user's own group).
~ $ groups pi john
The passwordless sudo configuration is in /etc/sudoers.d/010_pi-nopasswd
You can add your own user entry in that default file (or create separate files for each user -- personal preference).
Add a duplicate entry for your user under pi.
pi ALL=(ALL) NOPASSWD: ALL
john ALL=(ALL) NOPASSWD: ALL
And while you're in there, change the pi entry to PASSWD
pi ALL=(ALL) PASSWD: ALL
Which will require pi to use a password for anything requiring sudo (but john will still have passwordless sudo).
Now that won't completely eliminate password requests, as there is a timeout where the password entered in a session will allow multiple sudo commands to proceed without a password, if entered within the timeout period (which I believe defaults to 5 minutes). If you want your son to require a password for every sudo command, then run sudo visudo and add or edit the following line .
Defaults timestamp_timeout=0
The number is how many minutes the timeout period is. Zero means no grace period and every sudo command will require a password. You can adjust the number as needed.
And finally, add user john to /etc/polkit-1/localauthority.conf.d/60-desktop-policy.conf
sudo nano /etc/polkit-1/localauthority.conf.d/60-desktop-policy.conf
[Configuration]
AdminIdentities=unix-user:pi;unix-user:0;unix-user:john
Reboot when you've done all of this and you should be good to go.
Milliways
Sat Apr 20, 2019 1:15 am
Raspbian privileges are determined by group membership.
I avoid fiddling with sudoers - Just copy groups to the new user:-
	for GROUP in $(groups pi | sed 's/.*:\spi//'); do sudo adduser username $GROUP; done
fbe
Sun Apr 21, 2019 4:47 pm
[Configuration]
Or replace unix-user:pi by unix-group:sudo
[Configuration]
AdminIdentities=unix-group:sudo;unix-user:0
John50
Sat Apr 27, 2019 12:28 pm
Finnally i manage to give the same privileges to my new user as the pi have, now when i login into the new user and try to delete the pi user accound i get this result:
john@raspberrypi:~ $ sudo deluser pi
Removing user `pi' ...
Warning: group `pi' has no more members.
userdel: user pi is currently used by process 462
/usr/sbin/deluser: `/usr/sbin/userdel pi' returned error code 8. Exiting.
Somebody knows what I should do?
