Connecting a fan to the gpio connectors
Posted: Sun Nov 25, 2012 10:25 pm
by JPatrickDev
Hi :)
Im looking to get a small fan to cool my raspi, and im wondering what connector I need to be able to plug it into the GPIO ports on the pi? http://www.amazon.co.uk/Akasa-AK-4020MS ... 112&sr=1-1 is the sort of fan im looking for. Thank you for any help :)
Re: Connecting a fan to the gpio connectors
Posted: Sun Nov 25, 2012 10:40 pm
by joan
That fan is rated at 12V. The gpio pins can supply a few 100 milliamps at 5V. The fan might not even turn with just 5V.
Posted: Mon Nov 26, 2012 12:52 pm
by TonyD
Have you seen HotPi at Kickstarter
http://www.kickstarter.com/projects/582604098/hotpi
that has a fan output
Posted: Mon Nov 26, 2012 1:02 pm
by redhawk
If you're using the 5v output pin then you have as much power as the USB ports.
I'm also using a micro fan rated at 12v this works fine using 5v and although it spins a little slower there is sufficient air flow for cooling.
Richard S.
Posted: Fri Nov 30, 2012 11:35 am
by pyman
I've backed the project - have to wait a while though. Real time clock will be really useful when no network connection is available to set/get date/time in an application I am working on.
Posted: Fri Nov 30, 2012 4:08 pm
by notarat
I use a USB-to-3Pin adapter, like the one shown below
That particular one is listed on FrozenCPU.
I plugged the cable into one of the USB 3.0 Ports on my MondoHub and it works fine to power a 50mm fan.
