Hi guys,
I am new here so I dont really know if I am in the right place.
I've RaspberryPi 3b+
I got a problem with my fan, it's a fan for RaspberryPi and when I plug the fan to the raspberry the goes 100% all the time.
Very noisy, and it's good of course that the fan is always on 100% speed, there is a way to make him be on 50%?
or just turn on when the raspberry need?
Thank you so much!
Re: RaspberryPi Fan
Try using it without the fan!
One of the best features of the Pi3B+ is the advanced thermal management.
IMHO no fan is ever needed, regardless of the load.
A passive heat sink helps avoid throttling if your workload is extreme and sustained for more than a few minutes.
There are several cases on the market now made out of aluminum where the case itself acts as a large heat sink.
- Raspberry Pi Engineer & Forum Moderator
- Location: The unfashionable end of the western spiral arm of the Galaxy
Re: RaspberryPi Fan
You could connect it to the 3v3 line instead of the 5v line. Alternatively, Noctua have nice quiet fans if you want to overspend on one.
- HawaiianPi
Re: RaspberryPi Fan
Yup, Noctua fans are awesome. Not cheap, but worth the price. You definitely won't need a heatsink no matter how hard your 3B+ is pushed. I can run CPU Burn continuously on my 3B (not +) with no heatsink, cooled by a Noctua NF-A4x10 5V 40mm fan that I can barely hear (58C max).ShiftPlusOne wrote: ↑Fri Apr 12, 2019 8:53 amAlternatively, Noctua have nice quiet fans if you want to overspend on one.
An even better solution is to put your 3B(+) In a Flirc Gen2 case.
The case itself acts as a huge heatsink and keeps the Pi cool without the additional noise or power requirements of a fan.
Re: RaspberryPi Fan
With a bit of extra hardware you can control the fan speed based on the temperature.
See viewtopic.php?p=888016 as an exmaple.
Re: RaspberryPi Fan
Can you explain me how to do it? where do I plug it?ShiftPlusOne wrote: ↑Fri Apr 12, 2019 8:53 amYou could connect it to the 3v3 line instead of the 5v line. Alternatively, Noctua have nice quiet fans if you want to overspend on one.
After I am doing that the board need to stay right?procount wrote: ↑Fri Apr 12, 2019 9:32 amWith a bit of extra hardware you can control the fan speed based on the temperature.
Re: RaspberryPi Fan
There is a "simple hack" to silence a 5v fan...
me thinks it running loose in the internet..... need to find and catch it....
Some people be like:
- HawaiianPi
Re: RaspberryPi Fan
Well, you could use a 12V fan on 5V. Some may not run on 5V, but the ones that do will be very quiet. I used to have a double stack cooled by a single 12V 80mm fan that made almost no noise and worked very well. It kept both systems (and the SSD on the Pi) nice and cool.
This is a shot of that configuration when I was testing it (fan on top is a 40mm Noctua, but it's not connected for the test).
Re: RaspberryPi Fan
try this
remember ,never approach a computer thinking this will only take a minute
~~pi zero w and a 3b+
- HawaiianPi
Re: RaspberryPi Fan
I thought the 3.3V output was limited. Running a fan on that seems like a bad idea.
Re: RaspberryPi Fan
due to the "scare" that some fans connected to the GPIO headers ([5v or 3.3v] and ground pins) "killed" some of our forum-mate's RPis, I've made it a point never to directly connect any fan (or any inductive load for that matter) to any RPi GPIO header pins.
