I accidentally unplugged my power adapter while it was installing the latest updates
Posted: Wed Apr 10, 2019 12:41 am
by Kujal05
I need a bit of help...
Yesterday I got a new raspberry pi b3+ and it worked fine
Now it doesn’t work and I cannot use my keyboard/mouse
The boot up says something about kernel modules.....
Please help
Re: I accidentally unplugged my power adapter while it was installing the latest updates
Posted: Thu Apr 11, 2019 12:48 pm
by klricks
Fixing the original image may be very difficult or impossible.
Much easier to start from scratch and redo the SD card.
Posted: Thu Apr 11, 2019 1:08 pm
by rpdom
That is a situation it is difficult to get out of. The Kernel Modules (drivers) must exactly match the version number of the Kernel that is running the system. By interrupting the upgrade part way through you have ended up with a Kernel and Modules that don't match. Assuming you haven't done much on that Pi yet, it really would be easiest to download the latest Raspbian Stretch image and write that to the card using Etcher. Then you can start again (also, as a new image has only just been released, you shouldn't need to do any updates as they will already be on there.
If you do have something vitally important on your card and want to keep it, it is possible, but not that easy, to either recover the card, or to get the contents off. Both options would either require a Linux system with Card Reader, or another SD card with Raspbian on and a USB Card Reader for the Pi.
Posted: Thu Apr 11, 2019 1:10 pm
by LTolledo
Repeat the whole installation process again... from the start (except the pulling of the power adapter...) :D
Posted: Thu Apr 11, 2019 6:37 pm
by Roken
You could plug the sdcard into a PC, chroot into the SDCard and perform a:
sudo dpkg --configure -a
followed by
sudo apt-get update && sude apt-get upgrade
Once finished, it may rescue without re-installing.
Posted: Thu Apr 11, 2019 9:07 pm
by Greg Erskine
Note "sude" is a typo
