Recently, I've installed MiniDLNA in my RPi, but when I am going to use a USB... What happens? Nothing.
Simply, nothing. I've tried some tutorials on the web, topics on other forums... but nothing. I know that MiniDLNA (or ReadyMedia) are very very out-of-date, but I don't find another updated and that works on the RPi
Thanks!
MiniDLNA and the USBs
The rule for the RPi: sudo apt update
My English will be bad (I'm from Spain
Re: MiniDLNA and the USBs
Maybe tell us "how" you use the USB...but when I am going to use a USB...
Ohh... sorry, a USB Stick to have the media.
Meaning that stick already contains the files you hope to serve?
What Operating System is running on your RPi?
Is the usb stick correctly detected and mounted by the Operating System?
Can you navigate around the directories on the usb stick directly from the shell (command line) prompt on the RPi? (Or the GUI file manager.)
(Because the Operating System can only serve, via other applications, files that it can already 'see'.)
YesMeaning that stick already contains the files you hope to serve?
RaspbianWhat Operating System is running on your RPi?
Yes, I can access to the USB and read and write files. But when I change the config file of MiniDLNA (ReadyMedia) to the USB don't work. Like the directory doesn't exist.Is the usb stick correctly detected and mounted by the Operating System?
Where does Raspbian report that it has mounted your media files? (What would you type to list them?)
How have you modified miniDLNA or its configuration to incorporate those files?
- default_user8
Not to divert from your original topic, but what's wrong with the DLNA server in plex media server or Kodi's DLNA server? Both are current, and would probably solve your usb issue, Plex would certainly make it easier to curate your media collection.DPi wrote: ↑Wed Apr 10, 2019 2:09 pmRecently, I've installed MiniDLNA in my RPi, but when I am going to use a USB... What happens? Nothing.
Thanks!
Two heads are better than one, unless one's a goat head.
I've changed the minidlna.conf file with this line:
media_dir=V,/media/pi/USB1-D/Files/Videos
/media/pi/USB1-D type vfat (rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro,uhelper=udisks2)
I think about it but one of the computer that I like to use to see my files, can't use Plex; but thanks for your helpdefault_user8 wrote: ↑Wed Apr 10, 2019 4:05 pmNot to divert from your original topic, but what's wrong with the DLNA server in plex media server or Kodi's DLNA server? Both are current, and would probably solve your usb issue, Plex would certainly make it easier to curate your media collection.DPi wrote: ↑Wed Apr 10, 2019 2:09 pmRecently, I've installed MiniDLNA in my RPi, but when I am going to use a USB... What happens? Nothing.
Thanks!
After use advanced options for the command mount, I've seen that the device USB are mounted into the folder '/dev/sda1' but it has got a ""friendly name"" called /home/pi but really it's a type of shortcut to /dev/sda1/.
I've tried with some photos, videos and music and it works to me. It goes more slowly, but it works.
I've changed the minidlna.conf file and now is:
Thanks to everybody.
media_dir=P,/dev/sda1/Files/Photos
media_dir=V,/dev/sda1/Files/Videos
media_dir=A,/dev/sda1/Files/Music
