pjft
smbd-notifyd out of memory with large files
Mon Apr 01, 2019 9:05 pm
Apologies for bothering. I've had quite a few Pis so far for several projects, and recently decided to try out OpenMediaVault on an unused Raspberry Pi 3B (not the +) I had here, using a wired connection, and an external USB drive formatted as ext4. OMV is installed in the SD card.
Everything has been working spectacularly well, but yesterday I ran into an issue when trying to copy some "large" files (15GB) over Samba from Mac to it. It happened at first and I thought it had been a one-off error. The pi froze, SMB dropped, couldn't SSH into it nor access the GUI. I thought I would have to unplug it, but after some minutes it resumed activity as normal, so I let it go. SSH'd into it and rebooted it just in case.
The morning after tried again, same thing happened, and moments ago again so I'm thinking it's a fairly repeatable issue.
Here's part of the syslog:
pastebin.com/kCrL9uY4
I ran into a few similar issues on this and other forums, but they seem to suggest that this had been fixed in a previous kernel update. I'm on
Linux openmediavault 4.14.98-v7+ #1200 SMP Tue Feb 12 20:27:48 GMT 2019 armv7l GNU/Linux
which should be good, given the last reports were from mid-last-year.
forum.openmediavault.org/index…ng-up-gui-and-ssh-access/
raspberrypi.org/forums/viewtop…d24f1d39ae45d4bc&start=25
raspberrypi.org/forums/viewtop…208821&start=375#p1330384
The main thing from the log is that it seems that smbd-notifyd eats up all the memory and then only when it gets killed does everything resume normal activity.
I'm running "top" right now and watching things as they go, and indeed it's been steadily increasing and it's right now at 86% memory consumption, and starting to eat at the swap memory as well. EDIT: and it just died, after 9.28GB transferred, with 0 swap memory free and about 5MB free from the main memory :)
Is there anything I'm missing or should be reporting on?
Happy to help with anything. I imagine that I'll end up transferring this via rsync (maybe it'll happen the same) but wanted to share in case it helps - or if anyone has any more pointers.
Thanks and keep up the great work.
[I had posted this on the actual OMV forums, but since there seems to be some interest in these reports in this community as well, judging by the other post here viewtopic.php?f=28&t=208821&start=375#p1330384 I thought I'd share as it feels similar and might be related to something on the kernel side of things. Hope that's acceptable.]
