Yammers wrote: ↑Fri Apr 12, 2019 9:25 pm
I would like it to have on off button as standard.
Funny thing about that.... For a while (until WD shut it down), WD Labs made Pi accessories. One of them was a CM carrier board. They actually set the power up sufficiently to handle a CM3, when those came out. The normal purpose of the board was to provide a CM/CM3 with a SATA connection. The packaging, with a plastic frame (original versions of which came with magnets at the corners...very handy) is quite good.
There were...some design flaws. The first being, 2 USB ports and no Ethernet. The second being that the early boards work like a champ booting an MSD directly with a CM3L (once one sets the OTP bit). The problem is that later boards won't work that way. I think they changed out something in the USB hub and/or SATA bridge and later boards don't work correctly. (And...FYI...as soon as I get my hands on a CM3L+ I will be testing that to see if there are any changes that make late model WD SATA Adapter carriers work.)
One of the other features of the SATA Adapter board is...a real, physical power button.
Now to drag this back to the present... Even if WD Labs were still in operation and making Pi stuff, I don't think the SATA Adapter will work if we get a CM4L. The reason being that one hopes the Pi 4 SoC will have USB 3 and I don't know what effect that will have on the required pinouts to the carrier.
In a fairly recent video interview with Dr. Upton I saw, he said that the only times that the RPF/RPT gets into making stuff other than Pis is when either the market fails to do so or the items on the market aren't what they should be. I think the WD SATA Adapter falls into both categories. On the one hand, the lack of network connections and on the other, you can't get them any more.
So... What I'd like to see some time down the road (i.e. *after* the Pi4B and *after* there are CM4/CM4L modules available) would be a New, Improved, designed by the RPT SATA Adapter 4 carrier board. It could even include the power switch.
