Wireless display
Posted: Tue Mar 19, 2019 11:54 am
by mowatm
I'm doing a project that has a pressure sensor and level sensor and want to display the level and pressure on a display but want to do this wireless and not use internet any ideas.
Re: Wireless display
Posted: Tue Mar 19, 2019 12:49 pm
by lewmur
Not enough info. I'm assuming you are connecting the sensors to a Pi via the GPIO pins and want to "display" the readings remotely. How remote? In the same room? In another country? How many digits? What kind of accuracy? How often? Once an hour? Once every millisecond?
Posted: Tue Mar 19, 2019 12:56 pm
by Heater
zigbee:
https://elelabs.com/products/elelabs_zigbee_shield.html
https://hacks.mozilla.org/2018/02/how-t ... s-gateway/
bluetooth:
https://www.cnet.com/how-to/how-to-setu ... erry-pi-3/
LoRa:
https://www.hackster.io/idreams/getting ... ora-fd69d1
Infrared:
http://www.raspberry-pi-geek.com/Archiv ... -IR-remote
WiFi:
Can be used without going near the internet.
Perhaps if you said more about what it is exactly you want to do we could help better. What range do you need? What environment will it be in? What do you expect to transfer over wireless exactly?
Posted: Tue Mar 19, 2019 1:02 pm
by klricks
Not clear what you want but per your topic title Google [wireless HDMI] for example: https://www.amazon.com/J-Tech-Digital-W ... ooghydr-20
Posted: Tue Mar 19, 2019 1:18 pm
by mowatm
it would be up to 30 meters, to one decimal point and every millisecond
Posted: Tue Mar 19, 2019 2:02 pm
by mowatm
I am trying to measure pressure and level and have them displayed up to 30 meters away and would like the accuracy to be to one decimal point and i don't want to use WiFi and was thinking Bluetooth but unsure on how to do this
Posted: Tue Mar 19, 2019 2:16 pm
by fredoll
Why don't you want to use Wifi ?
I think it would be the easiest way.
you could have a pi that get the values from the sensors and another one that would display those values.
a 1 millisecond interval is not feasible anyhow.
Posted: Tue Mar 19, 2019 2:18 pm
by Heater
See this thread where they do just what you want:
viewtopic.php?t=182681
Updating at 1000 times per second is almost certainly not possible.
Why would you need such a high update rate anyway. A display will only refresh 60 times per second and the human brain viewing it will register the updates even more slowly.
