picandies
rainbow screen troble
Thu Mar 07, 2019 4:04 am
I have a nice custom image at bootup, but want the rainbow screen to go away...using latest stretch & rpi3.
I found these steps & repeated them EXACTLY & re-tried them 3 times...but during each boot the rainbow square (4 colors) keeps showing up...are these invalid edits? The display is a LCD plugged into the HDMI jack. I tried putting the suggestion at the bottom, then tried top of the config file, but still no luck.
Steps
1. Remove Rainbow Screen
1-1. Open “/boot/config.txt”.
sudo nano /boot/config.txt
Then add below at the end of the file.
# Disable rainbow image at boot
disable_splash=1
https://scribles.net/silent-boot-up-on- ... n-stretch/
W. H. Heydt
Re: rainbow screen troble
Thu Mar 07, 2019 4:07 am
If you mean the initial big colored square, that part of the VC4 boot process and there is nothing you can do about it.
picandies
Thu Mar 07, 2019 8:03 am
so what does this supposedly do?
6by9
Thu Mar 07, 2019 8:57 am
You're not quoting official documentation, so it could be any old twaddle.
It is in the official docs at the bottom of https://www.raspberrypi.org/documentati ... xt/boot.md, but I'm not in the office to confirm whether that functionality is still valid. I'd be surprised if it had been dropped though.
HawaiianPi
Thu Mar 07, 2019 9:02 am
Actually, disable_splash=1 in config.txt should work. Try it for yourself.
Not really sure why that doesn't work for you. It works fine for me. Must be something about your custom image? ¯\_(ツ)_/¯
...but I'm not in the office to confirm whether that functionality is still valid. I'd be surprised if it had been dropped though.
I just double checked it with the latest Raspbian (since I normally don't use that setting), and it still works as expected.
No GPU test (rainbow screen) with:
disable_splash=1
Yes GPU test (rainbow screen) with either:
#disable_splash=1
disable_splash=0
picandies
Thu Mar 07, 2019 10:12 pm
Are you using NOOBS? I thought I saw something about it not working with noobs...but not sure if/how that would make any difference. I'm using the latest NOOBS setup.
HawaiianPi
Thu Mar 07, 2019 10:24 pm
No, I don't use NOOBS. Why do you?
In my opinion, NOOBS causes more problems than it solves. I just use the Raspbian images (and the Etcher image writing utility). It's easier than NOOBS, and far less problematic.
