gebos1
Installing FFmpeg onto Raspberry PI 3
Wed Mar 06, 2019 10:39 pm
I am trying to install FFmpeg onto my Raspberry Pi but I am getting an error when trying to clone into github.com
The command I entered was:
sudo git clone https://github.com/FFmpeg/FFmpeg.git
The error Iam getting is:
Cloning into 'FFmpeg'...
fatal: unable to access 'https://github.com/FFmpeg/FFmpeg.git/': gnutls_handshake() failed: Key usage violation in certificate has been detected.
What can I do to get to get past this error?
ShiftPlusOne
Re: Installing FFmpeg onto Raspberry PI 3
Thu Mar 07, 2019 1:27 am
Also, don't put sudo in front of commands unless it's required.
gebos1
Fri Mar 08, 2019 12:14 pm
Ok I will keep that in mind. & Cjan that’s instructions on how to install ffmpeg but that doesn’t quite fix the error I’m having. Are you familiar at all with the error that I am getting?
Fri Mar 08, 2019 12:28 pm
Is not the version in the Raspbian Stretch repositories not suitable ??
Retired disgracefully.....
This at present is my daily "computer" https://www.asus.com/us/Chrome-Devices/Chromebit-CS10/
gebos1
Thu Mar 14, 2019 1:42 am
It appears I just did something wrong after typing cd~ which I believe was not needed before typing the sudo git clone command. I was following someones old code and was unsure. Thanks to all who attempted to help though.
