monisha.om
How to make gpio as chipselect
Tue Mar 05, 2019 5:31 am
can anybody help me to findout how to make gpio as chipselect. as there is 2 chip select provided by the pi. i need a third one .
so how can i done it?
Re: How to make gpio as chipselect
Tue Mar 05, 2019 7:18 am
There's five on the RPi if you enable spi0 & spi1.
https://pinout.xyz/pinout/spi
mark3112
Mon Jun 17, 2019 10:59 am
I used to use the dtoverlay command I don’t know if it’s still current though.
Info: Enables spi1 with three chip select (CS) lines and associated spidev
dev nodes. The gpio pin numbers for the CS lines and spidev device node
creation are configurable.
N.B.: spi1 is only accessible on devices with a 40pin header, eg:
A+, B+, Zero and PI2 B; as well as the Compute Module.
Load: dtoverlay=spi1-3cs,<param>=<val>
Params: cs0_pin GPIO pin for CS0 (default 18 - BCM SPI1_CE0).
cs1_pin GPIO pin for CS1 (default 17 - BCM SPI1_CE1).
cs2_pin GPIO pin for CS2 (default 16 - BCM SPI1_CE2).
cs0_spidev Set to 'disabled' to stop the creation of a
userspace device node /dev/spidev1.0 (default
is 'okay' or enabled).
cs1_spidev Set to 'disabled' to stop the creation of a
userspace device node /dev/spidev1.1 (default
cs2_spidev Set to 'disabled' to stop the creation of a
userspace device node /dev/spidev1.2 (default
You can make a real CPU in a FPGA, but you can’t make a real FPGA in a CPU.
lostman
Mon Jul 01, 2019 7:47 pm
I don't know whether the Xilinx spi driver supports that or not - I'd guess not - but you do not need to, anyway. Instead, you can rewire the SPI1 interface inside the FPGA and use the spi driver in it's standard way. On the FPGA-side, you'd have to
  • reconfigure the ZYNQ-IP to map SPI1 to EMIO
    enable one or two additional SlaveSelects on SPI1
    disable UART1
    route the new SPI1 connections on the IP to red_pitaya_top and tie them to FIXED_IO_mio[8-12] - that's where UART1 and SPI1 were previously
    make sure that the external drivers for the MIO pins are configured correctly - since the devices on them are now disabled, they will no longer automatically inherit their configuration
Lastly, increase the number of selects for spi1 in the devicetree. That ought to do it.
source: 192.168.1.1
