k2
Re: Counter Strike 1.6 ?n B model
Sat Jan 14, 2012 9:56 pm
Will it work CS 1.6 on raspberrypi because i found version for linux yet , so i saw a video on youtube there man was playing QUAKe so maybee it can run cs 1.6 , plz everyone who know apply me . Sorry for my english i am from russia
Prometheus
Sat Jan 14, 2012 10:39 pm
I've had a quick look, and it would appear that Counter-Strike is for x86 processors, and isn't open source, meaning that it won't run on the ARM-based Raspberry Pi (unlike x86 Linux, you cannot use WINE on ARM Linux).
Please correct me if I'm wrong, though.
Marlon
Sat Jan 14, 2012 10:54 pm
Windows
Windows XP or later
1.7 GHz Intel or AMD Processor (3.0 Ghz recommended)
512 MB of RAM (1 GB recommended)
DirectX 8.1 graphics card (DirectX 9.0 recommended)
This is from wikipedia and should answer your question
k2
Sat Jan 14, 2012 11:13 pm
Marlon are you crazy i am asking about cs 1.6 here true system req :
Minimum: 500 mhz processor, 96mb ram, 16mb video card, Windows 2000/XP/ME/SE, Mouse, Keyboard, Internet Connection
Recommended: 800 mhz processor, 128mb ram, 32mb+ video card, Windows 2000/XP, Mouse, Keyboard, Internet Connection
tzj
Sat Jan 14, 2012 11:22 pm
http://www.themagpi.com <---- Checkout the MagPi
(The MagPi - Co-Founder)
benatweb
Sat Jan 14, 2012 11:26 pm
The problem is not the CPU power, that might be enough - it's the CPU architecture. While nearly every home computer today uses the x86 architecture (Intel or AMD processors), the Raspberry Pi is based on the ARM one (smartphones usually have an ARM processor), cause else the projects aims (small and cheap) couldn't be reached.
Windows runs on x86 machines only so far (and the upcoming Windows 8 will require much more power than the Raspberry Pi has), and since cs 1.6 requires Windows it will be impossible, even if the device could be powerful enough.
kme
Sat Jan 14, 2012 11:36 pm
tzj said:
http://www.instructables.com/i.....-16-Linux/
may help, may not.
That's a CS server, not a client. You won't be able to play CS on an ARM based client.
madsheep
Sun Jan 15, 2012 12:09 am
wine+qemu is the key read this
http://wiki.winehq.org/ARM
also Golensrc engine is closed source so i found the Xash3d(Golensrc clone)
so a cs 1.3 can be played with a lot of work
asdfowkw
Sun Jan 15, 2012 1:41 am
Would it be possible to get a counter strike 1.6 server running on this :p ? with 100/100 mbit internet connection ?
bnolsen
Sun Jan 15, 2012 3:32 am
The game you'll have to settle for will be urban terror.  Hopefully its not too cpu heavy.  Being based off ioquake3 means there's hope it will actually run.12
k2
Sun Jan 15, 2012 8:40 am
So much work , but i didnt find answer . Will it work or not .........
Deedasmi
Sun Jan 15, 2012 8:52 am
k2 said:
So much work , but i didnt find answer . Will it work or not ………
It's been answered multiple times in this post.
It is not possible to play CS 1.6 on the Raspberry Pi
k2
Sun Jan 15, 2012 11:18 am
Will high defenition films works in Linux on rasperry pi if i download VLC ?
na1pir
Sun Jan 15, 2012 11:29 am
vlc probably not(at least not at first), but guys at xbmc are working hard, maybe we will get something from them...
Sun Jan 15, 2012 11:33 am
There will be a media player provided with the Distro. This can play back 1080p30 H264 (at least). You don't need VLC, and for the first version VLC won't use the acceleration
rurwin
Sun Jan 15, 2012 11:36 am
HD videos should work or RPi, and I believe will, using some player.
However I am not convinced VLC will work on RPi. Some people have reported some success porting the x86 code to ARM, but it appears to be highly complex and fraught with problems.
davidgoodenough
Sun Jan 15, 2012 12:20 pm
vlc is currently available for armel, but not armhf on Debian.  I think that the Pi's CPU does have hardware floating point, so one should use armhf, but I guess armel would work but slowly.  However mixing distributions in Debian is difficult so you would have either to wait for someone to port it to armhf, or run your entire system on armel.
Prometheus
Sun Jan 15, 2012 1:47 pm
It seems to work fine on the Pandora.
plugwash
Mon Jan 16, 2012 5:04 am
Hopefully that will be fixed before the pi is released.
derSuhler
Sat Jan 21, 2012 3:00 pm
sounds like a possible way for cs 1.6 on a raspi:
http://phandroid.com/2012/01/2.....-download/
via http://stadt-bremerhaven.de/
su_year
Sat Sep 19, 2015 6:59 am
now that win Iot can be installed on Rsp2, is it possible to run a cs1.6 server?
