Hi everybody,
I hope that I picked the right forum for my question. Please feel free to move my post otherwise.
I would like to use a 7“ touch display and a power button at the same time. I was thinking of something like this:
https://howchoo.com/g/mwnlytk3zmm/how-t ... spberry-pi
The Raspberry Pi touch display uses the the SCL pin 5:
https://thepihut.com/blogs/raspberry-pi ... mbly-guide
Is it possible to share this pin for both usages? Is there another solution to solve this?
Thanks and Regards,
Raspily
Re: Usage of Pi touch display and power button
It would be much better to change the GPIO pin for the shutdown button to one that isn't used.
The touchscreen uses SCL as a clock to transfer data from the touchscreen to the Pi. So it is waggling up and down quite a lot.
The shutdown button script is using that pin as an interrupt to detect any falling edge on that pin to cause it to shutdown the Pi. Do you see a problem there? It will be shutting down all the time.
Just chose another pin that isn't used and adapt the shutdown script accordingly.
PINN - NOOBS with the extras... https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=142574
I just read the first article the OP referred to. It uses GPIO3 specifically because grounding that will wake the Pi from a "halted" state.
However, I would suggest using TWO buttons, a GREEN button between GPIO3 and Gnd, and then pick an otherwise unused exposed GPIO for the shutdown function, on a RED button. (RED=Stop, GREEN=Go - although I'm colour-blind, what do I know).
Steve S
No, I can't think of anything funny that won't offend someone if they want it to...
Thanks for your feedback. I really appreciate it.
Would it be possible to use one button and connect it to GPIO 3 for startup and a different GPIO for shutdown? Similar to this:
https://volumio.org/forum/power-off-but ... 60-10.html
Thank you
Thank you
