dony71
Re: Easily run 64-bit Debian Buster packages on a Raspbian system: new RPi4 / RPi3 image released (systemd-nspawn, LXDE)
Wed Jun 17, 2020 12:22 am
after checking further, it appears aarch64-linux-gnu-xxx already available in 64-bit container
so i can run native gcc compiler in 64-bit container
now to compile a module, i need Module.symvers
i'm using raspbian-nspawn-64.img.xz release v1.4.8 from https://github.com/sakaki-/raspbian-nspawn-64/releases
anybody knows where i can get Module.symvers for this image?
NB: i grab Module8.symvers from https://github.com/raspberrypi/firmware ... 0601/extra
( for raspberrypi-kernel_1.20200601-1 kernel 4.19.118-v8+ )
but i get error below when compiling module
i guess this problem due to mismatch Module.symvers being used for kernel 4.19.118-v8+
FATAL: parse error in symbol dump file
make[1]: *** [scripts/Makefile.modpost:92: __modpost] Error 1
make: *** [Makefile:1526: modules] Error 2
make: Leaving directory '/usr/src/linux-raspberrypi-kernel_1.20200601-1
Botspot
Thu Sep 03, 2020 6:21 pm
@sakaki, would it be possible to remove the pulseaudio dependency from raspbian-nspawn-64 by having the guest 64-bit system connect directly to the host's sound devices?
That's the approach I took with vdesktop and it works quite well.
Ever wished you could "open" a RaspiOS .img file? Well now you can! I've developed Pi-Power-Tools, the only RaspiOS img editor on the planet.
https://github.com/Botspot/Pi-Power-Tools
Want to try it out?
wget -O - https://raw.githubusercontent.com/Botspot/Pi-Power-Tools/master/update | bash
