raspnoobfan
NTFS file partition?
Sun Jan 06, 2019 2:52 am
Is it possible to create a NTFS file partition on the micro sd crad used to boot raspian? I need to be able to transfer files over 4 GB and wanted a partition that you don't need to boot from but can still access on the same sd card.
thagrol
Re: NTFS file partition?
Sun Jan 06, 2019 12:11 pm
Yes but it would be simpler to use a USB stick formatted in NTFS or tranfer files over a network. ext4 supports large files, and the filesystem is largely irrelevant when transfering file over a network. You only need ntfs if directly connecting the SD card to a windows box to transfer files.
If you want to do it, the process is something like this:
  • Gather requirements:
    • Second SD card with raspbian or other computer running linux
    • USB card reader
  • Install ntfs-3g on both SD cards
  • Install gparted on the second card
  • Boot from second SD card
  • Connect original SD card via card reader
  • Run gparted
  • Reduce the size of the second partition
  • Create a new ntfs partition in the free space you have created
  • Apply changes
  • Boot from modified SD card
  • Create a mount point
  • Add a suitable entry to /etc/fstab
  • Reboot or manually mount the ntfs partition
This space unintentionally left blank.
raspnoobfan
Thu Jan 10, 2019 5:55 am
I wonder if having an NTFS partition on the boot sd card makes the system unsafe or more vulnerable to viruses?
Imperf3kt
Thu Jan 10, 2019 8:00 am
Since Microsoft Windows is not installed on that partition, no it doesn't.
It's no less safe than plugging a regular hard drive, thumb drive or optical media into a computer to transfer files.
55:55:44:44:4C
52:4C:52:42:41
thagrol
Thu Jan 10, 2019 11:35 am
Wrong.
It's not quite that simple. A Pi is immune to windows viruses because it's A. not running windows, and B. uses a different processor architecture.
If a windows machine has access to the partition, that machine has the same level of risk as it does with its own drives. As do the files on the partition.
Whether windows is installed on the Pi's partition is completely irrelevant.
Imperf3kt
Thu Jan 10, 2019 1:55 pm
Wrong.
The partition is on the microSD card in the Pi. A windows computer has no access to it.
And just having a partition doesn't make it more susceptible to viruses. That's like saying I'm more susceptible to car crashes because I own a car.
55:55:44:44:4C
52:4C:52:42:41
pws
Thu Jan 10, 2019 2:04 pm
But that is, in fact, true!!!
DirkS
Thu Jan 10, 2019 2:51 pm
Why would OP want an NTFS partition if there will be no direct access from a Windows computer?
Thu Jan 10, 2019 3:18 pm
I think the point was that the OP wanted to be able to shutdown the Pi, remove the SD card and put it in a Windows PC.
That might work with Windows 10, I'm not sure, I don't have any Windows machines to test with. With earlier versions it wouldn't work because they only recognise the first partition on an SD card.
Hmm... maybe it could work if partition 1 was NTFS, partition 2 VFAT (for /boot) and partition 3 ext4 (Linux root), as I seem to remember something about the Pi being able to boot from the first FAT partition it finds on the card. I could be wrong.
thagrol
Thu Jan 10, 2019 5:08 pm
Indeed, that's my interpretation of the OP's requirement too. There's no point in using an NTFS partition otherwise (well, not unless you're using the mass storage USB gadget functions, and that opens a whole new can of worms)
Only if your windows 10 install is upto date. Before, I think, autumn (fall) 2017 it still only mounted the first partition.
Nope. First partition must be FAT or it won't boot. You could use a bigger FAT partition (non-trivial due to limitations in Linux's partitioning software) but you'd still be stuch with the 4GB file size limit.
thagrol
Thu Jan 10, 2019 5:19 pm
That's an invalid assumption. Have you not heard of samba? nfs? sshfs?, http?, ftp?, etc? Or just unpluging the SD card and pluging it into a windows box?
If windows can read a file system it can be infected by a (windows) virus present on it. It doesn't matter if that filesystem is local or on a server somewhere. For remote file systems it doesn't matter what the filesystem is, the client doesn't care and doesn't know (unless using something like iSCSI or ATAoE).
If windows can write to a filesystem, a (windows) virus can infect it. Again it makes no difference whether the filesystem is local or remote.
Nor does it matter in either case what OS the server is running.
If windows couldn't infect files on network storage, there'd be no need for linux software that detects and removes windows viruses. Hint: such software does indeed exist.
plugwash
Thu Jan 10, 2019 7:39 pm
AIUI you can create it but it will be useless, windows will only access the first partition on a SD card and the first partition on the SD card needs to be the fat32 boot partition and.
hvdkooij
Thu Jan 10, 2019 8:09 pm
A virus does not infect a filesystem. It may however ruin files on it. Or put itself into files on the filesystem and hope to hop along. ......
But that is besides the scope of the question at hand anyway.
DirkS
Thu Jan 10, 2019 9:40 pm
IIRC that changed in Win10 not too long ago.
Have not tried it myself though
thagrol
Thu Jan 10, 2019 9:55 pm
Yes, I'm well aware that most viruses attack files, I could have explained things a little more pedantically. That said, if memory serves there have been viruses that attack filesystems, the MBR, and system BIOS.
thagrol
Thu Jan 10, 2019 10:03 pm
It did (around the end of 17/start of 18). It does. It's why you get popups about unformatted discs when connecting a raspbian SD card to a windows 10 box. At a guess, someone didn't read the entire thread before posting.
Fri Jan 11, 2019 10:40 pm
That may have been true with WINXP. It's not true with any modern supported version of Windows. They will hapily access any partition on any device as long as it's formatted with a filesystem type that's blessed by Windows.
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
raspnoobfan
Sun Jan 13, 2019 7:06 am
I was thinking since the NTFS partition is on the SD card is it no longer password protected the same way the raspbian OS is?
If so can a random attacker exploit that if you go online and infect your Raspberry with a virus?
thagrol
Sun Jan 13, 2019 4:41 pm
The password doesn't protect the OS or the partitions it just stops unauthorised folks from logging in. But if it's still the default it's no protection at all as this is well know.
As for going online, that depends on how you go online and what you're doing. For basic use: web, apt, etc it should be fairly safe as raspbian cannot run windows (or Mac OS) viruses. While linux viruses do exist there are far fewer of them, and those will likely have been created for x86 CPUs.
However, if you download an infected executable and later open/run it on it's target platform I can still infect your files.
To a large extent, it doesn't matter how the partition has been formatted. If windows/MacOS/x86 linux can write to it a virus running on that can infect the files.
Where you will hit problems with going online is if you start allowing incoming connections from the internet to your Pi.
raspnoobfan
Sun Jan 13, 2019 7:54 pm
I love the raspberry pi foundation. I learn so much about computers and electronics for something that was just a hobby by reading this forum. I thought the entire sd card was encrypted.
I like electronics so much that I think I might get a degree for it.
