thalastplaya
make .jar file launch at startup
Thu Nov 15, 2012 6:33 pm
Hey community
I am trying to make a .jar file (JDownloader.jar) launch at startup.
Can anyone tell me a simple way of doing this when it is with a .jar file?
Can I just put a file in /ect/init.d containing something like this:
#! /bin/bash
path to .jar file
Hope you can help me
Thx in advance
/Joe
elatllat
Re: make .jar file launch at startup
Thu Nov 15, 2012 6:47 pm
java -jar jarfile
java -help
use full paths, try it, and post any errors you get.
init.d is best for things without a GUI.
Use bashrc (or something) and check for X if you want to autostart a GUI
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
thalastplaya
Thu Nov 15, 2012 7:25 pm
elatllat wrote:
java -jar jarfile
java -help
I'm sorry..maybe you could elaborate that - I'm not that experienced with startupscripts
fabi280
Fri Nov 16, 2012 7:01 am
edit the rc.local
add something like
cd /path/to/jarFolder/
java -jar JarFile.jar
Should work. But it's not very elegant
cave
Fri Nov 16, 2012 9:44 am
Use pyLoad instead of JDownloader!
written in python, there is no Java Virtual Machine necessary, plenty of RAM for other functions available. :))
It's lightweight, nice android control app, and a wonderfull WebInterface for usage remote or on localhost.
And has similar features.
http://cavebeat.blogspot.co.at
thalastplaya
Fri Nov 16, 2012 10:55 am
fabi280 wrote:edit the rc.local
add something like
thx, I'll try that when I get home.
cave wrote:Use pyLoad instead of JDownloader!
I've tried pyload and actually thinks it is rather lightweighted, but I cannot seem to get the autoCaptas to work...or even just to manually enter captas..
Do you got any problem with them?
thalastplaya
Fri Nov 16, 2012 8:04 pm
Hmm
can I just add:
/media/Raspberry/jdownloader/
java -jar JDownloader.jar
any where in the rc.local?
thalastplaya
Wed Nov 21, 2012 9:29 am
Anyone?
ghans
Wed Nov 21, 2012 1:24 pm
I believe you did it the wrong way round. The path has to be prepended
to the .jar filename , not the java command.
ghans
thalastplaya
Wed Nov 21, 2012 1:45 pm
ghans wrote:I believe you did it the wrong way round. The path has to be prepended
ghans
hmm so like this: /media/Raspberry/jdownloader/JDownloader.jar
Can I just put it any where in the rc.locale?
elatllat
Thu Nov 22, 2012 3:16 am
/usr/bin/java -jar /media/Raspberry/jdownloader/JDownloader.jar
thalastplaya
Fri Nov 23, 2012 10:07 am
Where do I put that line?
I just tried to put it in the start of the rc.local-file, and that did not work
vNa5h
Tue Oct 01, 2013 2:30 am
bump...same query
ghans
Sun Oct 06, 2013 8:49 am
Try
sudo raspi-config
and select "Boot to Desktop".
Then
touch ~/startjar.sh
chmod +x ~/startjar.sh
nano ~/startjar.sh
add following lines :
#!/bin/bash
Save and exit.
Lastly , follow the instructions here to start the shell script
via LXTerminal + .desktop file :
http://www.raspberrypi.org/phpBB3/viewt ... 91&t=55824
ghans
