How to get the Serial USB comunication with a 4 channel relay board to work ???
Posted: Wed Dec 26, 2018 4:13 am
by JuliusCesar2017
Hi there i'm Julius and i have one Problem with my raspberry pi 3 b+.
So i'm trying to let the pi controll this rellay board
(https://www.amazon.com/SainSmart-USB-Ch ... elay+board)
for my school project with a Python code so that i can modify it easily.
But i tried alot of programs and dirvers and reinstalling the operating system (rasbian)(is this the right operating system for that would be great?) and stuff like that, so could please anybody help me and could tell where i have to start and how.
And i don't wan't to make any presure but it would be nice if we could solve that problem as fast as possible, do you understand?
If there are any questions you are free to ask.
Dear Julius.
:roll: ;)
Re: How to get the Serial USB comunication with a 4 channel relay board to work ??? HELP PLEASE SCHOOL PROJECT
Posted: Wed Dec 26, 2018 6:40 am
by DougieLawson
Posted: Wed Dec 26, 2018 6:48 am
by PhatFil
afaik you shouldnt need any drivers to use serial ftdi coms
to use python for serial coms Install PySerial, either
sudo apt-get install python-serial
for Python2, or
sudo apt-get install python3-serial
for Python3.
from the amazon page linked to
Open comm port at 9600 baud, 8 bit, no parity, 1 stop bit
no flow control. Mr. Merryman was correct in his command determination. The relays are selected by
binary where:
0001 = relay 1 on = Dec 1
0010 = relay 2 on = Dec 2
0100 = relay 3 on = Dec 4
1000 = relay 4 on = Dec 8
Let relayvalue = decimal value of relay desired
ie: relayvalue = 1 for relay one.
Then send chr$(relayvalue) to the comm port.
If you want multiple relays add their decimal values together,
1 & 4 would be relayvalue=9
To then turn relay 4 off, subtract 8 from relayvalue and send relayvalue=1, turning
off relay 4 and leaving relay 1 on.
Posted: Wed Dec 26, 2018 12:01 pm
by JuliusCesar2017
Hi thanks for that first help but the last thing what I would need is a python code that turns some relays on and of(you can decide which relay) and that runs without errors on the raspberry3 b+. And it would be great if someone could explain how to find the com port were the rellay board is connected. So that i can edit that in the code.
Thank you so much
We are getting closer to the finishline!!
Quick response would bee great because it is a schoolproject
Dear Julius
:D :P
Posted: Wed Dec 26, 2018 6:18 pm
by scruss
They don't seem to work directly using Pyserial, but here's a library with example code that should work for you: PyRelayCtl.
Posted: Wed Dec 26, 2018 7:25 pm
by pws
"Quick response would bee great because it is a schoolproject"
So....you want everyone to drop everything and hurry up and do the work YOU were supposed to do so YOU can get credit???
Happy New Year...
Posted: Wed Dec 26, 2018 8:37 pm
by bensimmo
/dev/ttyUSB#
or
/dev/ttyACM#
# being a number.
What and why and which.. have a look.
Posted: Wed Dec 26, 2018 8:53 pm
by gordon77
This thread may help
viewtopic.php?t=216670#p1336648
Posted: Wed Dec 26, 2018 9:02 pm
by W. H. Heydt
There is no pressure on anyone here. A lack of foresight on your part does not constitute an emergency for anyone else. Please show that you have done the work you should have done, including consulting with your instructor. And, by the way, if someone here tells you how to do your work, then you should arrange that they get your course credit for doing it.
Posted: Fri Dec 28, 2018 8:34 am
by gordon77
He came, He asked, but did He conquer?
