WCHD wrote: ↑Sun Dec 16, 2018 5:42 pm
Hi! I just installed my Raspberry Pi. I want to download BitDefender, but it is an .exe file. Wine needs ExaGear to run on RPi, but ExaGear is too expensive. How do I install Bitdefender without wine and
without exagear?
Use Pi386, a free x86 chroot environment, already set up and ready to use.
viewtopic.php?t=226376
A couple of people have reported issues with the custom kernel (with the 3G/1G memory split required to use WINE). To avoid kernel errors, use Eltechs' WINE 2G/2G version instead (it might be from Eltechs, but the custom WINE build doesn't cost anything).
I'm planning on releasing an update soon with the following features:
*Ubuntu 16.04 environment
*Sync with home folder
*Beta Debian Buster environment
Known issues:
*Does not emulate SSE2 support, so apps that require SSE2 will fail.
*Getting a segfault when running an app? The app probably requires SSE2.
*The kernel package includes no kernel modules, meaning that your Pi system may perform poorly if it works at all. The solution is to use the Eltechs WINE 3.0 build, which is available on Launchpad. This build does not require use of the custom kernel.
Ubuntu 18.04 LTS desktop images for the Raspberry Pi 3.
https://github.com/CodeExecution/Ubuntu-ARM64-RPi
