geoffr
EDUP WiFi adapter from Dealextreme
Wed Nov 14, 2012 10:13 am
Hopefully a piece of useful information:
I ordered an EDUP WiFi USB dongle from Dealextreme, URL to the adapter in question is:
http://dx.com/p/ultra-mini-nano-usb-2-0 ... pter-48166
The adapter worked on the latest Wheezy image straight out of the box - it was detected automatically. All I had to do was to configure /etc/network/interfaces, where I added the following details:
auto wlan0
iface wlan0 inet dhcp
wpa-ssid "<mySSID>"
wpa-psk "<MySuperSecretPassword>"
After that I was able to manually bring the interface up using ifup(8), and it came up on the next reboot.
coliscip
Re: EDUP WiFi adapter from Dealextreme
Thu Nov 15, 2012 7:36 am
thank you for infos. i want to make a order for this product. i see they make it cheaper 10.70$->8.99$ :D
it's my first order but i know that i have to wait... Yours in how many days arrived?
Willem
Fri Nov 23, 2012 11:58 pm
My latest DX order took 8 days to ship. This is exclusive of packaging times and such but it is so much faster compared to the past, where waiting times were like 5 weeks...
Thanks for the link, I might buy this adapter too seeing it is so cheap.
geoffr
Sat Dec 01, 2012 3:35 am
Just an additional comment about the adapter so far. I have found it mostly stable, with only one problem, which is not really related to the adapter:
The wireless AP that I have it connecting to does a scheduled reboot at 2am every morning, and when the Pi sees the WiFi network go down, it shuts down the WiFi adapter, and doesn't bring it up again. Since I have had an ethernet cable connected, I have been able to log in and manually bring the interface back up again. I need to find a resolution for this however, as, otherwise I cannot use the Pi in a wireless config where I need it to reconnect when the WiFi network goes down.
rukmal
Sat Apr 20, 2013 2:46 am
geoffr wrote:Hopefully a piece of useful information:
auto wlan0
wpa-ssid "<mySSID>"
Think you will have to comment the following line at the bottom for it to work.
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
Best is to set it up with a static IP. Here is what I have done.
iface wlan0 inet static
        wpa-ssid "<My SSID>"
        wpa-psk "<My Password>
        address 192.168.1.100
        netmask 255.255.255.0
        network 192.168.1.0
        broadcast 192.168.1.255
        gateway 192.168.1.1
#wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
rukmal
Sat Apr 20, 2013 7:12 am
geoffr wrote:Just an additional comment about the adapter so far. I have found it mostly stable, with only one problem, which is not really related to the adapter:
a good idea would be to run a cronjob to bring up the interface. you should schedule it to run after the reboot has occurred . this way the wifi would be brought up after every reboot without you requiring to log and do it manually.
Zgecko
Mon Apr 22, 2013 9:55 am
        network 192.168.1.0
        gateway 192.168.1.1
Does this work with WEP protocol too?
Like this:
        wireless-essid YOUR_SSID
        wireless-key YOUR_WEP_KEY
        network 192.168.1.0
        gateway 192.168.1.1
~Stefan
bluesed
Wed Jul 17, 2013 11:32 am
How does one get a command line on xbmc?
marzi
Wed Aug 14, 2013 9:20 am
This link helped me fix the reconnection problem when your router was rebooting at 2am
http://rpi.tnet.com/project/scripts/wifi_check
fesaiyan
Wed Nov 19, 2014 10:54 pm
Sorry because of my unknown but I have added the
auto wlan0
wpa-ssid "<mySSID>"
on /etc/network/interfaces but I can not use ifup, ¿how can I write this?
asandford
Thu Nov 20, 2014 12:41 am
fesaiyan wrote:Sorry because of my unknown but I have added the
auto wlan0
wpa-ssid "<mySSID>"
Did you substitute your values for <mySSID> and <MySuperSecretPassword>?
fesaiyan
Thu Nov 20, 2014 7:39 am
Yes I have substitute these values
fesaiyan
Thu Nov 20, 2014 9:40 pm
I have solved the problem, I need to write the ifup command in rc.local
DocPuneet
Fri Oct 02, 2015 11:39 am
Just ordered EDUP EPn8553 (new) nano wifi adapter for my new Raspberry Pi 2B. Will it work ? The Amazon FAQ answered no for that..but why? I think all Nano Adapters should work, even if there are minor tweaks required.
Please help, should I cancel my order and buy something which can simple plug and play out of box?
Thanks !
Fri Oct 02, 2015 12:38 pm
DocPuneet wrote:Just ordered EDUP EPn8553 (new) nano wifi adapter for my new Raspberry Pi 2B. Will it work ? The Amazon FAQ answered no for that..but why? I think all Nano Adapters should work, even if there are minor tweaks required.
Thanks !
It depends not on the manufacturer but the actual Wireless Chipset in the Adaptor, if you can find that information it would help ;)
Most adaptors can be configured to work in Raspbian OS, though with other availables OSes this may not be the case ;)
DocPuneet
Fri Oct 02, 2015 1:27 pm
Thanks !
Thanks for your prompt reply!
I am still waiting for the courier. On Googling I found some sites saying that the chipset is MTK7601.
Do you think, it will work?
Fri Oct 02, 2015 1:59 pm
Thanks !
Nice to know already asked :roll:
viewtopic.php?f=45&t=122028&p=823547&hi ... 01#p823513
