codaholic
A ton of question for raspberry pi.
Sat Dec 01, 2018 1:22 pm
I would like to setup a PC for coding and I got tons of questions for it:
Can somebody tell me how much percentage of the memory(RAM) does the OS take for it's own usage?
And Here's how I would like to use it:
Coding, possibly use nano or vim to save resource, ssh,sftp(from terminal too, if possible) and a bit of browsing. Would I get any problems when using Pi 3 B+? Like Lags or Hangs?
Can I use a 32inch TV screen as my monitor?
I don't know if I have nore, but it felt like much more earlier. Maybe they'll come again. Thanks.
DavidS
Re: A ton of question for raspberry pi.
Sat Dec 01, 2018 3:09 pm
That is highly dependant on the OS you choose to use and how you configure said OS. So multiple answers here:
  1. About 10% (100MB) For Raspbian Desktop, default config without any extras.
  2. About 8% (80MB) for Raspbian Lite (command line only) default config.
  3. About 5% (50MB) for a lite BSD installation.
  4. About 15% (150MB) for Ubuntu.
  5. About 2% (20MB) with a normal RISC OS config.
  6. I do not know about the other systems.
That again depends on the choice of OS, as well as the choice of tools, web browser, size of project being compiled, etc, etc.
YES:
If it has HDMI input that is the preffered monitor for use with a Raspberry Pi (HDMI TV that is).
If it is much older and only has composite input you will be limited to low resolutions.
jahboater
Sat Dec 01, 2018 3:45 pm
The Pi3B+ works very well like that and is quite fast. Perfectly usable.
Use scp for transferring files, it is very simple (like the cp command) and you can easily set it up not to require passwords (like ssh).
In my experience it will only lag of hang if you do something ridiculous.
Sat Dec 01, 2018 4:21 pm
codaholic,
"PC" now a days is taken to mean a big box running Windows or perhaps a laptop. Do you actually mean you would like to set up a Raspberry Pi for coding?
No idea, not much. I have never had to think about for all the coding I have done on a Pi.
And Here's how I would like to use it: Coding, possibly use nano or vim to save resource, ssh,sftp(from terminal too, if possible) ...
Sounds like a good plan. Works well for me.
...and a bit of browsing.
That is not coding. But browsers work well enough on the Pi. Apart from the difficulties people have watching Youtube or using webgl.
I have never experienced such for code I have created on the Pi. Depends what your performance requirements are.
I don't see why not. I presume it has an HDMI input.
It's best to keep to a single question/problem per thread. People are more likely to answer a specific question asked in a succinct and clear manner rather than wade though many paragraphs of noise.
jahboater
Sat Dec 01, 2018 4:40 pm
DavidS gave a good answer to that above, with numbers.
I agree, if you write code so bad that you run out 1GB of memory, something is wrong.
Sat Dec 01, 2018 9:36 pm
There seems to be a couple of posts by n67 and I deleted here.
What happened ?
drgeoff
Sat Dec 01, 2018 11:07 pm
What happened ?
There was a post mentioning "coding" as a term in social sciences. That isn't here now.
Sun Dec 02, 2018 12:10 am
drgeoff,
I'm glad you said that. I was starting to think I imagined it and am losing my mind.
n67
Sun Dec 02, 2018 12:41 am
Funny how it all works, innit?
"L'enfer, c'est les autres"
Epmu Sn!
Sun Dec 02, 2018 1:21 am
n67,
Just now it's giving me the creeps.
Perhaps I'll see the funny side in the morning.
codaholic
Sun Dec 02, 2018 2:13 am
Thank you for the replies, and thank you DavidS for the numbers, I will be using Raspbian OS, so I guess I won't have big issues, and maybe I should mention that I will not be compiling anything on the pi, I'll just SFTP/SCP it on another machine then ssh on it to compile.
DavidS
Sun Dec 02, 2018 2:40 am
Well then you are going to have no issues at all. Fair warning there are pit falls in cross compiling.
The RPi 3B/3B+ is way more than powerful enough to allow for compiling though, just so you are aware.
codaholic
Sun Dec 02, 2018 2:44 am
Thanks. I guess I should really go and buy some pi :-D thanks.
DavidS
Sun Dec 02, 2018 3:38 am
No problem. I bought my first in 2012, when they just came out, now just ordered my first 3B+ (already having all the full sized models inbetween[B/B+/2B/3B]). And I am on my RPi 3B now (still waiting for my 3B+ to get to me).
Sun Dec 02, 2018 7:59 am
What happened ?
I deleted some OT posts that were going to disrail the thread. Please keep on topic. Discussion about social sciences? Not on topic.
Imperf3kt
Sun Dec 02, 2018 9:04 pm
People often forget the GPU needs to use some of that RAM. If you're doing anything that requires graphic performance, you can expect about a quarter of that to disappear, poof, gone.
Add the system overhead and you're nearly half out of your RAM already...
55:55:44:44:4C
52:4C:52:42:41
Sun Dec 02, 2018 9:20 pm
When I was a lad, we had 32k of memory, and 20k of that went on the frame buffer. Still managed to program some good stuff.
jahboater
Sun Dec 02, 2018 9:25 pm
[When I was a lad, we had 32k of memory, and 20k of that went on the frame buffer. Still managed to program some good stuff.
We had a large mainframe at college. 512k words of memory. It supported a whole university. Post grads doing scientific research, countless under grads.
One computer I programed had 1k of memory and had to be programmed in hex (no Z80 assembler). A friend and I managed to solve the 8 queens problem on it. While the memory was being accessed the screen went snowy!
512GB of free memory ..........
Imperf3kt
Sun Dec 02, 2018 10:30 pm
When you were a lad, computers ran on 8bits and displayed half a dozen pixels a second and did one thing which would take hours or even days to do.
Now they run on 32 or 64 bits and display billions of pixels every second and do thousands of things simultaneously in seconds.
Every time I see this "when I was a lad" nonsense, it irritates me greatly.
This is 2018, not 1967
Computers are a lot more powerful, but they also use a lot more resources.
By the way, 'pong' can still use just a small amount of RAM on a modern PC, but most people are no longer impressed by a white dot slowly bouncing back and forth.
https://scratch.mit.edu/projects/98686485/
55:55:44:44:4C
52:4C:52:42:41
code_exec
Mon Dec 03, 2018 5:52 am
The recommended OS for the Pi (Raspbian) is optimised so that it takes up as little memory as possible. If your Pi is lagging and you have six Chromium tabs open with a YouTube video playing in each one of them, then blame that, not the OS itself.
Also, you can use a 32 inch screen as a monitor, but if you get issues such as black bars around the display output, you may need to modify some stuff in config.txt.
Ubuntu 18.04 LTS desktop images for the Raspberry Pi 3.
https://github.com/CodeExecution/Ubuntu-ARM64-RPi
bensimmo
Mon Dec 03, 2018 9:14 am
For the record, if it's a Pi3B or 3B+, you can just do it all on the Pi itself with Desktop Raspbian, unless you prefer to program in nano etc and not a nice desktop IDE.
You can also VLC/RDP if needed.
Even the web browsing, though you may find that does get 'laggy' in places. Probably as Chromium needs a good chunk of the RAM set aside (192MB I think still ?) and is a huge program taking up the RAM even with the ad blocker supplied.
Mon Dec 03, 2018 9:18 am
You have ENTIRELY missed the point. Of course machines nowadays are more complex, and the software is more complex (ever worked on a camera ISP - shoving huge amounts of data around at high speed?). But much software on these complex systems nowadays is also badly writtten. Having a limited system FORCES engineers to learn efficient ways of doing things. Give someone infinite memory, and you get crap, memory hungry code because there is no need to be frugal.
So rather than being irritated, learn to write better code by using a constrained system. It's actually a useful skill now we have IoT devices with very limited resources. The Pi is profligate in memory compared with IoT devives.
W. H. Heydt
Mon Dec 03, 2018 3:18 pm
Back in the day when IBM first started shipping machines with virtual memory support (anyone else remember "DAT boxes"?), the programmers around me all started saying things like, "Wow! Now we can use as much memory as we want!" I replied with two terms: "locality of reference" and "thrashing". Then I proceeded to point out that virtual memory is *not* a panacea for not wanting (or not being able to) write tight code.
On a Pi it is even worse, as normal operation involves the use of a storage medium with a rather limited lifespan...especially if you write to it a lot, which managing virtual memory (aka "swap space") certainly does.
jahboater
Mon Dec 03, 2018 3:25 pm
Didn't IBM place a huge full page advert in the Times newspaper with just the words "IBM Announce Paging" ?? !
Quietly forgetting that other mainframe manufacturers had been doing it for years.
Imperf3kt
Mon Dec 03, 2018 8:40 pm
Jamesh, you are an experienced coder, so you know how to improve and optimise code.
Beginners don't even know how to code, let alone optimise it.
What is more important, learning to drive, or learning to minimise fuel consumption?
Cart before the horse...
I do apologise as I know this is somewhat rude, but I do think that your multiple decades of experience is blinding you to how beginners feel.
55:55:44:44:4C
52:4C:52:42:41
