bdrmachine
printf problem
Tue Nov 27, 2018 5:35 pm
I'm using netbeans to write code for my remotely connected Pi. Could someone please explain to me why printf works with this code:
#include <stdio.h>
#include <stdlib.h>
int main(int argc, char** argv)
    int x;
    //for(x=0;x>5;++x)
    for(;;)
    printf("hello c WORld");
    return (EXIT_SUCCESS);
Sending the "hello c World" message to the output window in netbeans.
BUT
This code executes without sending anything to the output window:
#include <stdio.h>
#include <stdlib.h>
    int x;
    for(x=0;x>5;++x)
    //for(;;)
davidcoton
Re: printf problem
Tue Nov 27, 2018 5:40 pm
I can't see any difference between the two code blocks.
Please post code in [code]...[/code] tags so that white space is preserved.
DavidS
Re: printf problem
Tue Nov 27, 2018 5:53 pm
Both are the same. Did you accidentally double copy the same file?
ethanol100
Re: printf problem
Tue Nov 27, 2018 6:34 pm
for(x=0;x>5;++x)
is wrong.
You start with x=0 and it is never bigger than 5. This will just skip the printf block. Try < instead of the >.
n67
Re: printf problem
Tue Nov 27, 2018 6:35 pm
They are NOT the same. Look more carefully. (Unless, of course, OP has edited since the responders responded)
The problem is this:
for(x=0;x>5;++x)
It should be pretty obvious what's up with that...
"L'enfer, c'est les autres"
Epmu Sn!
PeterO
Re: printf problem
Tue Nov 27, 2018 6:54 pm
If it isn't obvious....
for(x=0;x>5;++x)
Reads as "Starting with x set to 0, while x is greater than 5 increment x"
You want "less than" rather then "greater than"
PeterO
Re: printf problem
Tue Nov 27, 2018 7:12 pm
ethanol100 wins - he was first!
n67
Re: printf problem
Tue Nov 27, 2018 7:59 pm
Actually, I started my post first - but took longer to compose and post. He slipped in.
Epmu Sn!
