Zizico2
Solved: Run Pythom Script as a daemon
Wed Nov 21, 2018 4:01 am
Hi guys I've got a script that defines some event triggered functions. I would like it to always be running in the background.
I'm thinking of putting an infinite loop (While(True):
Pass)
at the end and running it on startup (running it on bootlocal.sh).
Will this work? And is there any better way?
Thanks in advance!
PhatFil
Re: Run Pythom Script as a daemon
Wed Nov 21, 2018 4:22 am
afaik there are 2 prefered methods you could use (google)
1) systemd https://www.raspberrypi.org/documentati ... systemd.md
and
2) rc.local https://www.raspberrypi.org/documentati ... c-local.md
Zizico2
Wed Nov 21, 2018 5:44 am
and
Will this work without a loop at the end? Won't the script just end?
PhatFil
Wed Nov 21, 2018 6:08 am
yes you will need an endless loop to encapsulate the monitoring code
Zizico2
Wed Nov 21, 2018 11:03 am
Noob Python question: will event triggered functions get triggered during time.sleep()?
