kevink619
Why is it so difficult to install PHP 7.2 in RPi3?!
Wed Oct 31, 2018 8:37 am
Can someone please tell me how to install PHP 7.2 on my Raspberry Pi 3?
I can never get it to install. And I don't have "buster" - whatever the heck that is.
RaTTuS
Contact: Twitter YouTube
Re: Why is it so difficult to install PHP 7.2 in RPi3?!
Wed Oct 31, 2018 9:08 am
what have you tried ?
what instructions are you following
Covfefe
klricks
Wed Oct 31, 2018 1:08 pm
The current version of PHP in the Raspbian "Stretch" repository is 7.0
Why do you think you need 7.2?
Raspbian is based on the Debian Linux distribution.
The current version is Debian 9 which is code-named "Stretch"
Debian 8 was named "Wheezy"
The next release Debian 10 is named "Buster" (Approximate release in mid 2019)
The names are taken from characters in the Toy Story movies.
New releases come out about every 2 years and will have newer but not necessarily the latest versions of user software packages included.
allfox
Thu Nov 01, 2018 8:11 am
I see that they have a new version of Node.js in Raspberry Foundation's repository.
Don't know how they decide which package could get update in this way.
PHP is quite like Node.js, I think.
I believe Web is changing(advancing) too fast these days, reinventing too much wheels.
Thu Nov 01, 2018 11:27 am
You can build PHP7 from source code, but it's non-trivial task and it takes a long time (may be faster on a 3B+, it's been a while since I went through that pain with PHP5).
This script https://gist.github.com/matthiasbayer/2 ... 4793c527cc may help.
Thu Nov 01, 2018 12:51 pm
allfox,
Most packages in Raspbian come from Debian from which it is derived. When Debian updates a package that eventually finds it's way into Raspbian. Packages get updated by their package maintainers who are generally volunteers. The maintainers build the package and test it before it goes into use. So it's understandable that the packages in Debian/Raspbian can lag behind the latest versions.
Only if you have only glanced sideways at some source for less than a minute.
Apart from both being interpreted language systems with some superficial C like syntax, they are vastly different. Built for different purposes. One can do a lot more, more easily, with node.js than PHP.
Perhaps but PHP and Javascript have been around since almost the beginning and both are much the same. Javascript especially has done an excellent job of maintaining backwards compatibility.
Moving from PHP 7.0 to 7.2 or updating node.js is not so much reinventing the wheels as polishing the old ones.
Thu Nov 01, 2018 12:58 pm
I don't think I can say what we're polishing with PHP7.2 in a public, family friendly forum. But we're using Kiwi's finest brown polish for it.
allfox
Thu Nov 01, 2018 1:26 pm
But Debian Stable only have Node.js 4.8.2. The RPF have the version 8 for current Pi, which should be for Debian Testing.
It looks like PHP is not that lucky. (I didn't do a apt search for PHP)
I remember dnsmasq also had a newer version on Pi in RPF's repo.
It's good, but not that fair for other package.
dmausner
Mon Feb 18, 2019 3:56 pm
I will second the OP's implied request for a RPi3 compilation of PHP 7.2 (or 7.3).
One good reason for this request is that php.net issue library corrections in 7.1, 7.2, and 7.3, but many (or most) corrections are not back-ported to 7.0.
On other Linux platforms, in order to obtain library updates, I have upgraded from 7.0 to at least 7.2. This is not currently possible on Stretch, which leaves us with bugs known to be fixed in later versions, but not installable today. This presents reliability and security issues for production RPi3 maintainers.
Respect to all volunteer RPi3 code coordinators.
rpdom
Mon Feb 18, 2019 4:05 pm
I guess you didn't read the stuff about Debian policy and what "Stable" means.
Never mind, in a few months time Stretch will be replaced by Buster and that will have newer versions of most packages.
Unreadable squiggle
serendipitus
Fri May 31, 2019 7:43 am
On Ubuntu there is a solution which also seems to work on RPi3. I managed to install it successfully as there is a package for Stretch.
https://www.colinodell.com/blog/201711/ ... ing-php-72
ccpizz
Sat Jun 13, 2020 11:19 am
If you need a more recent version of php for a specific app, for example nextcloud, then check out if the app is available as a snap.
For nextcloud you could use:
sudo apt install snapd
sudo snap install core
sudo snap install nextcloud
sudo snap start nextcloud
This will install sandboxed versions of php, apache, redis and nexcloud which will be readily available for configuration via the webui wizard at http://your_raspberry_ip
Details for the next cloud snap: https://github.com/nextcloud/nextcloud-snap
