rapi22
powering Raspberry from USB router port ??
Fri Oct 26, 2018 11:30 am
I'm wondering if it could be possible to power a Raspberry from the USB port of a router like Huawei B525s-23a.
I don't need keyboard and screen, maybe a CSI camera.
Is there someone who ever tried this kind of thing ?
Thanks in advance for your advises and help
Regards
scotty101
Re: powering Raspberry from USB router port ??
Fri Oct 26, 2018 11:34 am
It totally depends how much power the USB port on the router can supply. Typically a supply that can output 2.5A at 5v is recommended. If the router is only designed to power a USB storage device for updating the firmware, it is unlikely to provide this.
It also depends which model of Pi you use? The Pi Zero requires much less power than all the rest. A Pi3B+ is very power hungry.
rapi22
Fri Oct 26, 2018 11:46 am
thank you for your reply. It makes sense. I will try to find another solution.
Regards
Fri Oct 26, 2018 11:53 am
Regards
https://www.raspberrypi.org/documentati ... /#pi-power
drgeoff
Fri Oct 26, 2018 11:55 am
Depends. I've had a Zero plus USB Wi-Fi dongle combination running PiHole powered from the USB port of a BTHomeHub6.
W. H. Heydt
Fri Oct 26, 2018 1:45 pm
The nominal spec for a USB port is to be able to supply 500mA. That's enough for a Pi0, Pi0W, or A+. It's not enough to meet the specs for any B-series Pi, and especially not enough for a Pi3B+.
rapi22
Fri Oct 26, 2018 3:09 pm
Thank you for your help
Regards
