picandies
solid pwm for motor
Sat Oct 20, 2018 11:57 pm
Hello, I need a rock-solid (hardware PWM) for precise motion control, at only 1800-1980 Hz at the pin. Really it only needs to be 50% at all times.
My understanding is just using some random I/O pin for PWM may give a lot of jumping (I have seen it myself) due to creating it in software, rather than a timer register. It appears I/O 12 is good for hardware/solid pwm, but what library will drive it as a hardware wave (rather than software)? Which packages are software only? I haven't seen it stated one way or the other.
Also I have another PWM device on GPIO22...what is the best I can do there? need about 1500Hz, 50%
B.Goode
Re: solid pwm for motor
Sun Oct 21, 2018 6:33 am
Have a look at the pigpio library. http://abyz.me.uk/rpi/pigpio/
The developer/maintainer is a regular contributor to these forums and is very well informed about this topic.
Joel_Mckay
Sun Oct 21, 2018 11:34 am
The atmega2560 has no problem running 10 hardware PWMs at a time. (I have used these to run several DRV8833 at a time)
If you are looking for a half/full h-bridge driver, than the pic18f4550 has a special pwm that handles this task (10bit precision if I recall).
Best of luck,
J
