DarkPlatinum
Power supply for Rpi 3
Sat Oct 20, 2018 6:17 pm
Hello, does anyone know good power supplies that are cheap from the RPi sellers? I find paying 8 pound for a power supply is a bit much. I have loads of 1 Amp power supplies around the home, apple chargers, micro usb, etc that might be able to power a Rpi 3 but not sufficiently.
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3 1 * Raspberry Pi 3B + :mrgreen:
Check Out My Raspberry Site (Run on a Raspberry Pi 3B :) ): Https://Html.dynu.net
Re: Power supply for Rpi 3
Sat Oct 20, 2018 6:56 pm
It is not expensive for quality, also many power supplies are chargers and will not hold a stable voltage / amperage. Buyer beware !
adieu
My other Computer is an Asus CS10 ChromeBit
DarkPlatinum
Sat Oct 20, 2018 7:37 pm
Yeh I already have one official one but i was wondering if there were any cheaper one for the same quality. I am using a 1 amp apple charger for my pi zero w, a ipad 2.4 amp charger for my pi 2, and a official for the RPi 3b+. I have another ipad charger but if I use it my brother will complain lol :P
The RPi 3 will be headless for a flight tracker.
W. H. Heydt
Sat Oct 20, 2018 8:33 pm
For the quality, the RPF PSU is pretty cheap. I would be suspect of anything that significantly undercut it unless I was dealing with a *very* reputable supplier. You might be able to beat the price by buying in bulk. I remember MCM (now absorbed into Newark/Element14) was discounting decent PSUs...if you bought 10 or more at a time.
FYI...if you think the RPF PSU is too expensive, try pricing a proper bench power supply.
PhatFil
Sat Oct 20, 2018 9:23 pm
the £2 poundland 5v transformer usb plugs sustain a 2.4a draw according to big clives utubes iirc, i have 3 x headless pi-0-w s running off them ..
Andyroo
Sat Oct 20, 2018 11:02 pm
I tried a Pi 3 off one and ordered the real on the same day :oops:
It’s fine for a zero or two - not tried three :shock:
PhatFil
Sun Oct 21, 2018 12:56 am
3x pi-0 s each with its onn psu not 3x driven by a single psu..
DarkPlatinum
Sun Oct 21, 2018 8:08 am
How big are the transformers? And how long is the cord? My Raspberry is about 1.2m away from a socket.
Thanks,
Y
drgeoff
Sun Oct 21, 2018 8:55 am
Thanks,
Y
More or less the same footprint as a squared up 13 amp plug and slightly thicker. Two USB sockets, no USB to micro-USB lead supplied.
DarkPlatinum
Sun Oct 21, 2018 9:47 am
Thanks,
Y
Does it look safe? Any downsides? etc. I might get one since there is a poundland a couple miles away. Hopefully they sell it.
W. H. Heydt
Sun Oct 21, 2018 3:48 pm
If the Pi is too far from an outlet for the USB cable to reach, start with a extension power cord to get the PSU closer to the Pi.
PhatFil
Sun Oct 21, 2018 5:17 pm
poundland £2 usb psu is im afraid only a 2.1a output device as i discovered when looking for the following u-tube which disects the lil bugger..
https://www.youtube.com/watch?v=aS1pwoVdRh4
DarkPlatinum
Sun Oct 21, 2018 5:45 pm
I guess its still pretty good but powering a pi 3 not so good. For 2 quid its still a bargain.
DarkPlatinum
Tue Oct 23, 2018 8:55 pm
Okey dokey got a power supply for £10, pretty good because it comes with universal adapters like the Raspberry Pi foundation power supply and it comes with a powerbank(3000mAh) and outputs 2.5 amps via two USB sockets, plus it has another mains socket. Lookin here(middle photo on URL): http://drycom.uk/
