suibaf
two address ip in raspbian stretch
Sat Oct 20, 2018 9:19 am
with Jessie I have no problem to set for eth0 2 ip address. In Stretch it no work.
My goal is to have in streatch 2 statip ip address or, better,
one assigned from dhcp and one static.
Thanks in advance.
Re: two address ip in raspbian stretch
Sat Oct 20, 2018 11:25 am
Add this
    auto eth0
    iface eth0 inet static
        address 192.168.3.14
        netmask 24
        gateway 192.168.3.254
to /etc/network/interfaces [change numbers to suit your network].
Leave /etc/dhcpcd.conf alone.
That's just about guaranteed to get a static and a DHCP address assigned to your eth0 interface.
suibaf
Sat Oct 20, 2018 1:17 pm
What do you mean?
dhcp assign to raspberry 192.168.1.197/24 and it's ok.
I need anoter ip: 192.168.9.150
BR
Sat Oct 20, 2018 3:58 pm
I mean don't change /etc/dhcpcd.conf from the version supplied when you installed Raspbian Stretch first time.
suibaf
Sun Oct 21, 2018 7:50 am
Hi DougieLawson,
it does not work maybe I need two different class IP address.
DHCP IP 192.168.1.10
Static IP: 192.168.0.150.
If I add your code in interfaces:
 auto eth0
        address 192.168.0.150
        netmask 24
        gateway 192.168.0.1
DHCP fail to assign the ip address.
Is there a solution?
BR
Sun Oct 21, 2018 8:34 am
One possibility is to assign an alias interface in somewhere like /etc/rc.local
Add the line
/sbin/ifconfig eth0:0 192.168.0.150/24
before the "exit 0" line and it should create a virtual interface called eth0:0 with that IP address which will use eth0 as the physical interface. It seems dhcpcd hasn't got the ability to handle interfaces like that.
suibaf
Sun Oct 21, 2018 2:20 pm
Hi rpdom,
it work fine! Thank you! :)
Why this code must be write in /etc/rc.local?
BR
