Metonics
Raspbian install not working
Fri Oct 19, 2018 11:59 am
I am simply unable to install anything on my RPI!
I have done the apt-get upgrade/update many times but always get unmet dependencies when trying to install any package
Paul Hutch
Re: Raspbian install not working
Fri Oct 19, 2018 1:00 pm
Seems like it's either a bad uSD card or a bad copy or burn of Raspbian on the card. Try downloading a fresh copy of Raspbian and creating a new uSD. If that works then try putting the fresh copy of Raspbian on the old uSD card and see if that works, if it does you had a bad download or burn, if it doesn't the old uSD card is bad.
HawaiianPi
Sat Oct 20, 2018 12:10 am
This is either a corrupt Raspbian install, or you added something to the sources which is not compatible.
Corruption could be due to a bad download, bad install, not properly shutting down the system before turning off the power, or you upgraded from an earlier release (Wheezy, Jessie), which is not a recommended procedure.
