Willrocks07
Raspberry Pi 3 B+ overheating
Tue Oct 16, 2018 5:54 am
My raspberry pi 3b+ is overheating a lot and cpu speeds are randomly jumping to 99-100 at any random moment can anyone help? :D
Willrocks07
Re: Raspberry Pi 3 B+ overheating
Tue Oct 16, 2018 6:06 am
This shouldn't have anything to do with it but i am booting from usb
RaTTuS
Tue Oct 16, 2018 7:19 am
sudo apt install pastebinit
ps axOT | pastebinbit
have you forwarded ports on your router to it so you can access it via the internet?
have you changed the default password ?
what have you installed
what are you running
Covfefe
jahboater
Tue Oct 16, 2018 9:01 am
What do you mean "speeds are randomly jumping to 99-100" - do you mean 100% utilisation?
To show the temperature, use:
[email protected]:~ $ vcgencmd measure_temp
temp=40.8'C
Too high and it will throttle back.
Here is a handy script for monitoring the Pi :-
#!/bin/bash
Counter=14
DisplayHeader="Time      Temp    CPU        Throttle       Vcore"
while true ; do
  let Counter++
  if [ ${Counter} -eq 15 ]; then
    echo -e "${DisplayHeader}"
    Counter=0
  fi
  Health=$(perl -e "printf \"%19b\n\", $(vcgencmd get_throttled | cut -f2 -d=)")
  Temp=$(vcgencmd measure_temp | cut -f2 -d=)
  Clockspeed=$(vcgencmd measure_clock arm | awk -F"=" '{printf ("%0.0f",$2/1000000); }' )
  CoreVoltage=$(vcgencmd measure_volts | cut -f2 -d= | sed 's/000//')
  echo -e "$(date '+%H:%M:%S') ${Temp} $(printf '%4s' ${Clockspeed})MHz $(printf '%019d' ${Health}) ${CoreVoltage}"
  sleep 10
done
It clearly shows any throttling.
If (and only if) your Pi is throttling then you may add a heat sink to maintain performance.
Willrocks07
Wed Oct 17, 2018 6:48 am
Thankyou for replying,
im mean 99-100 cpu usage ill try running that script
