ltalexan
Getting Started with Raspberry Pi PID Temperature Controller
Mon Oct 15, 2018 6:47 pm
Salutations Raspberry Pi Forum Browsers!
I am a senior undergraduate student in chemical engineering. For my senior design project, I have been tasked with building an automated temperature controller for a kamado-style smoker, like the Big Green Egg. After researching the subject extensively, most similar projects I have found online have been seemingly complicated from a hardware standpoint (at least for someone who has little background in electronics). For example, this project (https://github.com/CapnBry/HeaterMeter/wiki) includes tons of resistors, capacitors, etc. For the project, I would need ways of connecting type K thermocouples (at least 2) to a Raspberry Pi, and a way to connect a variable speed blower (controlled by pulse width modulation) to a Raspberry Pi. Is all of the complex circuitry in the project above necessary for this?
From my understanding, I should be able to execute the above functions with a thermocouple amplifier breakout board such as the MAX31855 and somehow modifying some of the GPIO pins for pulse width modulation to control a variable speed blower. Is this correct? Any pointers or explanations I can get would be helpful.
Thanks!
Gavinmc42
Re: Getting Started with Raspberry Pi PID Temperature Controller
Tue Oct 16, 2018 1:19 am
It is not really that hard. (unless you really want to do it in Linux).
Temperature sensors and heater/blower controlled by solidstate relays.
I do this for Real time Polymerase Chain Reactors (DNA replicator) , did not even need PID software.
PWM not needed either as thermal time delays are quite long ie 100ms, even 500ms+.
Started with Python on Linux, but the OS got in the way of my i2c temp sensor reading.
So now I use baremetal on Pi with Ultibo.
All that other stuff is nice but mostly frosting on the cake.
Sensor/relay and some simple software, start there and get that working first.
Once that is working then you can add data logging and screenshots of temperature plots etc
https://ultibo.org/forum/viewtopic.php? ... screenshot
Or even webpage plotting
https://ultibo.org/forum/viewtopic.php? ... tting#p373
I'm dancing on Rainbows.
reted30
Mon Oct 29, 2018 10:03 am
For K type thermocouple I have been using the ADS1115 I2C module.
But for controlling Pwm, use FET driver MIC5021
and will be easily connected with raspberry pi using I2C interface.
Mon Oct 29, 2018 10:22 am
A dedicated MAX31855K is a better amplifier for a K-type thermocouple.
