mahjongg
Re: under voltage detected
Sun Mar 10, 2019 9:44 pm
ebolisa wrote:
Wed Mar 06, 2019 10:54 am
Will do but I thought to follow through for being the same subject.
True, the rule is one question warrants one subject, and no more than one, this forum with >1356872 (one point three million!) posts is cluttered up enough already.
So duplicates will be deleted without warning, or hesitation.
I will only do a quick judgment with copy can most likely be missed the best , but I'm only human, and unless I doubt my decision enough to move the post to a user unreadable place, (which is taxing the patience of other moderators, so it happens *very* seldom) deleted copies cannot be recovered.
rakurs
Fri Aug 09, 2019 10:53 am
I have realy 1 task for my raspberries developments - to show video from digital camera on screen. Nothing more. I have about 20rasps + 20 PSU's.
I dont wanna see on screen this sign "under voltage detected" , turned wifi, bluetooth off. Added string to "config.txt" - yellow build to the right up corner - gone.
How to remove under voltage on screen sign? annoying.
I know, im under voltaged (2100ma) - but thats enough for my tasks, i can even underclock CPU. But i think it wount help with this sign coming to console screen.
how to remove it?
Raspi is custom, thats why im kinda at a loss about "we have no function to remove it, its an smoke detector!" - ok, for everyone its ok. For me - i need this option.
Fri Aug 09, 2019 11:43 am
rakurs
Mon Aug 12, 2019 12:24 pm
avoid_warnings=1
does't remove popup warnings in tty console, only yellow bulb on the right up corner
trejan
Mon Aug 12, 2019 12:33 pm
Create a file called /etc/modprobe.d/raspberrypi_hwmon.conf with "blacklist raspberrypi_hwmon" inside and it won't load the kernel module that monitors for undervoltage.
Imperf3kt
Mon Aug 12, 2019 10:11 pm
The proper and recommended solution is to get a better power supply. (and sometimes the cable between power supply and Pi)
Don't just sweep the dirt under the rug - just because you can't see it doesn't mean it isn't there and isn't a problem.
55:55:44:44:4C
52:4C:52:42:41
HawaiianPi
Mon Aug 12, 2019 10:23 pm
Or use a Pi computer with lower power requirements.
... turned wifi, bluetooth off..
Why not use a Pi2 (or perhaps a Pi Zero) instead?
rakurs
Thu Aug 22, 2019 10:56 am
THANX ! a lot !
Changing to other computer is't an option when you already have 20pcs.
I made downclock.
